Newbie, carb questions
Hi all. im a newbie to the carbed lsx lifestyle. i currently have a 383 lsx with AI heads and cam, around 13.5CR, and gonna spray a 300 shot with a direct port on a super victor carb setup. Ive been reading the new thread but would like some info on which carb i should run. i hear the holley 750 is good, but what about a demon? also deleting my knock sensors is the idea? I am also going to be on E85, do i need a specific carb for that? Whats a good fuel pressure for the fuel side? also is there a regulator that i can use to maintain for both the fuel for motor and fuel for nitrous side? im going to run a stand alone fuel system on it. i have a 98 pcm, and hp tuners, is there any adjustments i need to make for before the initial start up? sorry for all the questions, i am a super newbie to the lsx carb. thanx for all the help in advance.
Pretty safe to say you are going to need bigger than a 750 carb. There have been a couple of members running Quick Fuel E85 carbs. You might look into that. Contact quick fuel and see what they recommend. Also see if you can dig up any of the old E85 threads.
Get the MSD ignition box, it has everything you need including the stand alone harness. No knock sensor, just cam, crank and map sensor. Nothing to do with the old PCM or FI wiring, just get rid of it.
That is a lot of nitrous. You will probably get some pretty good suggestions on here for a fuel system but you are definitely going to want to do some more reading to make sure you are safe.
I will look into the threads and contact Quick Fuel as well.
The MSD 6LS is the one i need correct? that will replace my ECU? Ill post up my wiring setup when i get off work. Im not running a factory wiring setup. Im curious as to how that will have to be "tied" into my current wiring.
As for the nitrous, im going to start off on 250 fogger more than likely. than later ill spray 2 stages, 150 shots off a plate and a fogger. The rotating assembly is a forged lunati setup with total seal rings, (non gapless). it should hold up what i want to throw at it, but its all hope lol.
Cool, yea ill call up QF and see what they have for me.
I appreciate the help guys. also, do you use a tps on this setup? and as for the MAP, i just plumb a hole for it in the intake and use the stock sensor?
HP tuners? You shitcan that and get yourself one of these
Yes, the MSD box replaces your computer and entire engine harness. You can download some free software from MSD to set custom timing curves. To dial in your carb best to invest in a wideband O2 sensor. You will also need an assortment of jets and replacement gaskets, some standard wrenches and yes, a screwdriver or two. You might need to buy a nozzle or two once you get tuning and the quick fuel carbs have replaceable bleeds and such. Your best friend will be the internet for tuning info.
Be prepared to get some gas on your hands. Carbs are definitely more hands on than EFI
The tool above serves two functions especially with a Holley. One end makes fine tuning adjustments to A/F The other end you use to clear trouble codes by grasping the shank and then using the handle to clear the carb of its errors via several sharp blows to the float bowls.
All in all it's a wireless, plug and play solid state interface to the tuning data you have in your head!
lol thats funny ****. well damn, i guess ill have alot of parts to sell...im not so new to carbs, i have a blow thru carb on my 81 camaro, but im new to lsx being carbd. im sure its still different to some degree so i do need to learn more. i have a wide band so i can moniter than, now im just curious on how you guys get your car registered. In phoenix, i have to pass emissions to get it registered. its easy with obd but now what...lol. thanx for the input once again guys.
Going carbed on an LS is pretty much turning the engine into old school setup. The MSD box would be your distributers equivalent , although its capable of doing a lot more than an old school distributer ever could. You basically need to forget everything you ever learned about HP tuners. Instead, find an old mechanic that has been hidden in an old junk yard out in the boonies that still knows what a carb is. He will hold the light force you seek. You should bring an offering ( beer ) so he will know you are worthy of the knowledge he possesses . He will most likely speak in a lost dialect from a time long ago ( I recommend watching Nascar to learn the language ). May the force be with you, my brother.
I lol'd at this ****. But for serious tech now, I did a carb swap on my 4th gen and just left the factory computer in to run all my gauges and other miscellaneous stuff but your setup will look cleaner then mine also lol. If I was you I would look towards a quick fuel or a holley hp ultra. That way you have as much tuneability as possible for your part throttle driving. My new motor I'm building is gonna have a quick fuel on it.
heres a picture attached of my "diagram" so far. still need lots to go.
if you buy a plain old Holley you can drill out the press in air bleeds and other restrictions and replace them with brass set screws you drill yourself. That way you get the tunability of a quick fuel or Holley ultra but can buy the bleeds for a fraction of what the screw in ones cost for the high buck carb.
Getting a purpose built E85 carb is the way I would go though.
Quickfuel 850 E85
http://www.summitracing.com/parts/qf...-e85/overview/
Holley 850 E85
http://www.summitracing.com/parts/hl...44hb/overview/
well im going to end up getting the holley one.just got my income tax so time to order some parts. im wondering what pump and regulator to run tho. and how much PSI? im looking at these. any thoughts?
http://www.summitracing.com/parts/hly-12-150/overview/
http://www.summitracing.com/parts/hly-12-840/overview/
