Guess HP for my setup
Having a setup put together. Looking to see if anyone has a similar setup or if anyone can guess what type of horsepower it'll put out. Here are the details:
383 Stroker 11.5:1 compression
AFR 210 Heads
236/248 .520/.540 113 LSA
Vic Jr.
830CFM Holley
Thanks in advance.
AFR 210 Heads
Vic Jr.
830CFM Holley
Thanks in advance.
Not even close....
Your run of the mill 383 with GOOD parts can make 400-450. A junk slapped together mess of missmatched parts will net you 350-380 roughly.
We can't tell exactly cuz it's a crap shoot, build it and report back when the car is dyno'd.
AFR 210 Heads
Vic Jr.
830CFM Holley
Thanks in advance.
AFR 210 Heads
Vic Jr.
830CFM Holley
Thanks in advance.
LSA really has nothing to do with it. Two cams with the same LSA can have very different amounts of overlap.
And I also agree that this build wasn't thought through very well. Might still be quick, but not like it should be.
I would also say your cam is holding you back a lot. A custom cam would suit you better. A 113 LSA is more like a turbo cam spec. A 110 or 111 LSA for a N/A motors would work and sound a lot better. The duration is fine but the lift on it blows. Their are custom grind cams for stock motors that has more lift than that. I think lift around 570+ will give you the full effect.
96Capricemanager will post something shortly and tell you exactly what you need to do.
But im guessing around the 395-425rwhp. Maybe???????
I hav a 350 and it makes more power on a dynojet lol
