Ysi
Old 01-28-2014, 11:45 PM
kpadlina's Avatar
Default Ysi
How easily would 800 rwhp be to reach with a YSI without cog drive, using 91 octane? Probably around 17lbs boost
Old 01-29-2014, 02:53 AM
Blackbob's Avatar
Very,what is your base engine to start with ?
Old 01-29-2014, 06:52 AM
stevieturbo's Avatar
Well, you dont mention what drive you intend using. But 800hp will be no problem to the blower with a suitable belt drive.
Old 01-29-2014, 07:04 AM
Exidous's Avatar
Depending on CR with your 383 I'm assuming, you can certainly do it. 8 or 10 rib at a minimum.
Old 01-29-2014, 08:08 AM
kpadlina's Avatar
Cr is 10:1 and the belt I'm running now is 8 rib so I was hoping to stay with that set up.
Old 01-29-2014, 08:45 AM
the more ribs the better, but not all belt drive setups are equal. So make sure it is a damn good setup with a good sprung tensioner.
Old 01-29-2014, 10:11 AM
Exidous's Avatar
The Ysi and F Series benefit from a more steep gear ratio allowing larger pullies to be used. I'd love to run an F-1 but I want the helical gear set more.
But yes, more ribs are better for your boosting pleasure.
Are you planning meth? At 10:1 w/ 91 Octane I do not see 800whp or 17psi being possible at all. Maybe 9:1.
Old 01-29-2014, 10:27 AM
YSi and F-series internal gearing are miles apart.
F-Series uses much taller gears and hence larger pulleys. YSi as with most Vortech is down around 3.45
Old 01-29-2014, 10:59 AM
Exidous's Avatar
Huh no kidding. I honestly thought is was up there with the 5.x:1 of the F series. My bad.
Old 01-29-2014, 06:42 PM
kpadlina's Avatar
I'm willing to run meth. I just wanted to stay out of the e85 group cause sometimes it's hard to get and unfortunately the gm computer can only have one tune at a time
Quick Reply: Ysi
