E.t. Streets With Stock Rear End?
With stock converter and gears, I'd say you'll probably be ok... if you get a higher stall converter and move up to 3.42 or 3.73 gears, then you'd be putting the 10 bolt in danger.
With 26x11.5x16 ET Streets and a 3800 stall, my 10 bolt lasted for about 20 runs before it let go. It had 3.23 gears. Carrier bearings went and teeth on the gear broke. I think it was a combination of the sticky tires and a 50k mile rear that did me in. Some people have good luck, some don't.
Jeff
Jeff
I had good luck, but my days now (with the new cam) are numbered. I left off the limiter multiple times on ET's with 3.42's M6 and stock cam. Now I added about 50 rwhp and a few thousand miles on the rear. Best leave lately is from 4,000 on Nittos.
Originally Posted by 02WHITEZ
i broke my 10 bolt at the track with a nitto leaving at 4,000
gota love s10 rearends
