Walbro 416
Walbro 416
Hi, guys. This is my first post here although I have been lurking for a while now. I am new to the turbo world and looking for some fuel pump information. My project car is in my signature and I am having a Turbonetics 7875 installed. I am only looking to run about 10lbs of boost for around 550-600 rwhp. It currently has a Walbro 255lph pump installed which I don't believe will support my goal. Anyone have experience running the Walbro 416? I have searched all over the site and have yet to find anyone running that pump.
I'm running a Walbro 400 (416); silent compared to the 255. I suggest you hardwire the pump (if you haven't already done so with your 255). I'm using 10 gauge wire from the battery to a new relay as well as directly from the relay to the pump (using the factory fuel pump wire as a trigger for the relay).
those times were with three 255's on e85 but I redid the whole setup this last year and was gunna run the nasty tank with the magnafuel 4303 pump but from what I've found two of these pumps will flow quite a bit more
