Intercooler mounting
I am looking for how others have mounted their intercooler systems. The more pictures the better. Please share your setups!
My build:
02 camaro
On3 setup
My build:
02 camaro
On3 setup
here's how I mounted mine on my 72 chevelle-I orig had a Procharger sheet metal one, but it was to wide-this is a Treadstone one, thicker but 2" shorter
I welded a 90 deg on one end, snaked the pipes thru the core support
I was able to lower it to uncover some of the radiator, and keep the hood latch
least amount of cutting
then mounted the EMUSA 31x11x3 bar and plate intercooler.
then of course started running charge piping
while running the lling pipe, i ran the wastegate reference line and oil pump wiring
mind you mine is a rear mount so my pipe routing might be different then yours.
