Reroute go head coolant lines for ls6 intake
The other option is to just cap the rear ports and run a LS6 style front only crossover tube.
Andrew
I think I'll try taking it slow with the dremel.
This also brings up another good question, should I bypass cooling the throttle body? If I shouldn't where do I run the outlet on the throttle body? I can't were where I would return it (the coolant) out of the TB....
Ok so I trimmed the bottom of the intake and everything is lining up better, trimming it was easy.
However I still need to figure out what to do with the coolant lines. Cap or run? I think running them would be best. With that where do I route the output of the coolant? I have no idea where to run it to complete the cycle
The hose attached to the metal lines that are under your intake hooks to one side of the throttle body, the other side that comes out of the TB goes to the radiator in a factory application, I usually have a fitting added to my radiator. Some people drill and tap the water pump for a fitting, or you can T it into the upper radiator hose, there's places you can get the adapter to do this, Jagsthatrun I believe makes them. If you're going to bypass the TB, just run the hose from the metal lines to wherever you want to tap the line into.
