My defrost button (on my 93 TA) doesn't light up when pressed. Help me :(
Like the title says, whenever I press the button the button doesn't light up like it's supposed to.
Save the manuals!
It could be a number of things, but the easiest thing to check first (and the most common point of failure) is that circuit breaker.
I recall that there are two 30A breakers on the car. One is for the windows/defogger. Just switch the two and see what happens. If it works, you just need to get a new breaker.
If it doesn't work then, you'll need to do some electrical tracing and/or check out the relay/timer unit in the dash.
NAAA fuse is a one time one fault device, the breaker is designed to limit current flow in the circuit if it goes too high and reset to allow it to flow again. After doing this over and over the breaker starts to fail and needs to be replaced.
The fuse is slower acting but only acts one time then needs replacement.
