Alt to starter Cable recomendations ?
I bought some battery cables from Detriot Speed Eng. and they are by far the nicest cables I've ever had. I believe they are repackaged "QuickCar" I'd look into the gauge you want from them. FWIW
Good cable is expensive. the more strands, the better and the more expensive
http://www.wiringproducts.com/automotive-battery-cable
http://www.hifisoundconnection.com/S...8083/SFV/30046
I've had good luck sourcing cable off Honda's in the pick and pull.
Welding Cable FTW!
I used 4Ga and 1Ga high strand count welding cable for my re-wire process. It is worth it to spend the extra $$ to get the nice soft cover stuff for its flexibility. And the best way I found to cut it was a cutoff wheel on a 4.5” grinder. I also used brass ring terminals from my local welding supply store.
Size wise I ran 1Ga from the trunk mounted battery to the starter, and then 4Ga for the alt to “power distribution center” to starter. Using an amperage calculator; the 4Ga is more than sufficient for 150A for the length of run.
I have more info in my build thread if you are interested.
Thanks for all the info guys I really like this place also it has the SGX high temp jacketing and it is free shipping plus I always like USA made stuff
http://www.advancemcs.com/sps/connectivity/battery-cable
They have an ad on eBay for alternator to starter cable
