Luk LS7 vs Luk LS1 Replacement Clutch
Old 03-09-2014, 04:42 PM
ponchjoe's Avatar
Default Luk LS7 vs Luk LS1 Replacement Clutch
Ok, I am forced to replace the slave so I might as well do the clutch too. (74k miles) My car is mostly stock with no real plans for major mods and is driven on nice days. The only thrashing it gets is running it through the gears every once in awhile.
Is there an advantage to replacing the stock unit with an LS7 type unit or no big difference? I am most likely going with the Luk clutch based on the budget I am working with unless someone chimes in and sways me for a good reason.
Thanks guys!
Old 03-10-2014, 04:28 AM
Exidous's Avatar
I do not think the LS1 clutch is sold anymore. It's an LS6 clutch. The LS7 is a very common option for folks that are bolt on or less and don't really beat on the car too much. (drag) If factory replacements were my options the LS7 all the way. The extra overhead compared to teh LS6 clutch is nice reassurance to have.
Old 03-10-2014, 09:40 AM
Orange Juice's Avatar
The LS7 drives like stock. Really a great value.
Old 03-11-2014, 10:22 PM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
The LS7 clutch needs it's own unique flywheel. It won't just bolt up to a stock LS1 flywheel. So if you want to go with the LS7 clutch, you will have to get a matching flywheel, otherwise go with the LS6 clutch, which will bolt directly to your LS1 flywheel.
Andrew
Old 03-15-2014, 09:29 AM
itwillboost's Avatar
Just bought the LUK LS7 clutch and flywheel. I will post up my findings/opinions later this week.
Old 03-15-2014, 09:04 PM
ponchjoe's Avatar
And I went the other way with the LS1/LS6 Luk clutch.
Old 04-10-2014, 08:05 PM
SSmith's Avatar
You will love the LS7 clutch. The flywheel is heavier but the clutch is awesome. I also went with the Tick Master Cylinder.
Old 04-10-2014, 09:42 PM
chrysler kid's Avatar
Just buy a clutch setup from autozone with the lifetime warranty. They sell luk clutch kits
Old 04-10-2014, 11:32 PM
Pontiacerator
RevGTO's Avatar
The standard Luk kit for our cars (LS6) will be more than fine for your needs. No need to fool with the LS7. Plus you may be able to get away with resurfacing your flywheel rather than buying a new one. In fact, if your car has been treated well, there may be another 50k in the stock clutch.
Old 03-10-2016, 07:00 AM
apollyon_01's Avatar
Anyword on how it worked out?
I just ordered LFW191 flywheel, and will be getting GM p/n 24255748 to go with it. That flywheel was just such a good deal I couldn't pass up, but I can get GM employee pricing on the pressureplate/clutchdisk, and it's more or less the same price as the LuK 04216 kit.
I already have all new GM bolts and LS1 slave to go with the install in a couple weeks.
Old 03-10-2016, 09:25 AM
murphinator's Avatar
if you haven't installed it yet go with a lightweight flywheel that matches up with the ls7 clutch , it is a heavy setup in stock form and f body hydraulics struggle to handle it , it will block you out of shifts at WOT , its also harder on the synchros meshing all the extra rotating mass
Old 03-11-2016, 09:25 AM
blackandgold's Avatar
Even for a stock car, with a heavy clutch like the LS7 I vote for an upgraded MC. At a minimum drill mod your stocker while everything is apart.
Old 08-12-2016, 02:59 PM
Q3131A's Avatar
What are the part numbers for the LS6 and LS7?
I download their catalog and looked at Rockauto. 04-173 and 04-905 are the numbers I see. I can't find any info about LS6 or LS7.
Old 08-13-2016, 12:02 AM
whatsa347's Avatar
Luk pro gold is the LS7, if you go to rock auto, click on 2007 corvette for the manual transmission, the luk on it is the LS7 kit. It's like $200, and you can resell the slave that comes with it for pretty much what you paid for it.
Old 08-16-2016, 11:09 AM
Stew2000's Avatar
04-905 is the LS7 clutch,04-173 is the LS6
Old 08-16-2016, 11:14 AM
Q3131A's Avatar
Thanks, that's what I assumed. Looks like I'm replacing everything. Don't want to but sorta have to at this point.
Old 10-13-2016, 12:09 AM
Aaron Porche's Avatar
not accurate....
The only thing spinning on the input shaft is the clutch disk. syncros dont care how heavy a pressure plate or flywheel weighs. and the hydraulics only care about the pressure from the pressure plate.
Old 01-18-2018, 11:28 PM
Denom's Avatar
Originally Posted by Aaron Porche
not accurate....
I'm just curious if the luk 04-905 clutch comes with the correct flywheel? I see amazon selling the kit pretty cheap. Also can't you just machine a steel flywheel to reduce mass? I've heard horror stories regarding aluminum flywheels.
Old 01-19-2018, 09:31 PM
That kit is complete. I bought it from amazon and am using it in my Cougar.
Andrew
Old 01-19-2018, 10:55 PM
Denom's Avatar
Andrew
Thanks Andrew
Quick Reply: Luk LS7 vs Luk LS1 Replacement Clutch
