6.0L heads with 5.7L gaskets
Old 03-11-2003, 10:57 AM
nfshotrod's Avatar
Default 6.0L heads with 5.7L gaskets
If I have 6.0L heads can I use the 5.7L head gaskets or do I have to use 6.0 head gaskets?
Thanks
Old 03-11-2003, 11:17 AM
CamM's Avatar
Default Re: 6.0L heads with 5.7L gaskets
Need to use the 6.0L gasket or a little bigger (approx. 4.10 bore) if you are gonna spray nitrous since you could possibly have problems with the gasket not sealing properly.
Old 03-11-2003, 02:10 PM
nfshotrod's Avatar
They have had a clean up pass done.
Old 03-12-2003, 12:12 AM
Z00
Z00's Avatar
Are the heads milled any?
Old 03-12-2003, 05:08 AM
akw408's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by CamM:
<strong> Need to use the 6.0L gasket or a little bigger (approx. 4.10 bore) if you are gonna spray nitrous since you could possibly have problems with the gasket not sealing properly. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Is this from personal experience or did you hear this? If the gasket didn't seal properly, why would the problem be limited to nitrous only?
Old 03-12-2003, 07:02 AM
CamM's Avatar
A friend of mine has the same heads as me and was spraying a 100 dry shot. When spraying, he was getting bubbles in the coolant overflow tank. It was discovered he needed to use a larger bore gasket than 4.00 to prevent lifting of the head.
Old 03-12-2003, 10:55 AM
Texas Terminator's Avatar
<strong> Need to use the 6.0L gasket or a little bigger (approx. 4.10 bore) if you are gonna spray nitrous since you could possibly have problems with the gasket not sealing properly. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">that would be correct.
akw408-this applies to all blown/sprayed applications more than n/a due to the higher actual cylinder pressure.
Old 03-12-2003, 08:23 PM
akw408's Avatar
Ohhh, good to know. I actually have 6.0L heads with 5.7L gaskets right now, but haven't noticed anything yet. I'll keep an eye out for it and swap if I see anything.
What is the PN on the 6.0L gaskets?
