water pump advise
water pump advise
My water pump is leaking and I just wanna know if should change anything else while i have it off or tips on doing this job to make it easier.
What pump you get? I had to change my Bosh water pump that went 120k, sound great right? But the inlet where the top hose connects to was corroded, funny as corroded as it was it didn't lead there but i did remove a lot of crude and metal shaving from the hoses cause of the corroded pump. I went with a autozone pump cause low on funds and good or bad am only leaving this pump on for 50k, i recommend get a gm pump, my original didn't corrod as this one did.
Cool...thanks for all the input. I just asked in case there was something I should also do while I had it off. I did it on my lt1 and hated life!
Even though they are much more coin, the Evans pump for the LSxes is pretty stout since they upgrade the bearings/seals over what the factory/new GM/Delco part has installed, also a higher flow/higher quality impeller.
But yes, you DO pay for it over even a brand spanking new AC Delco/Delphi/GMB/whatever.
