What compression ratio for 1000rwhp 408
Old 03-29-2014, 01:29 PM
Freefallin's Avatar
Default What compression ratio for 1000rwhp 408
Im pretty new to the FI world so plz bare with me.
Been searching for info on basically a 101 on compression ratios for boost but to no avail.
Im looking to build a boosted 1000+rwhp 408 iron block but have no idea what cr to go with. For one thing, i don't want it to be a pig off boost.
Any knowledge you can throw my way would be really nice!
Old 03-29-2014, 03:01 PM
THADD's Avatar
I'm 10.5:1 cr on a 347 and 22+ psi boost
Old 03-29-2014, 03:05 PM
Kip Fabre's Avatar
Making 1000 + rwhp with 408ci will be easy with that many C.I. There are a few combination you could use but one would be 9.5 static. With the correct cam it will drive good and make the power you are looking for.
Old 03-29-2014, 05:08 PM
01transampower's Avatar
I live in Denver and we're gonna run my 408 at 10.3:1 or so to help with street drivability.
Old 03-29-2014, 05:21 PM
stevieturbo's Avatar
And the most important question of all.....what fuel ?
And unless it's a 5 ton truck, I doubt even a 408 could ever be considered a pig off boost at any compression.
Old 03-29-2014, 07:07 PM
Freefallin's Avatar
Fuel would be 91 and car is a GTO. Although not a truck it sure weighs like one.
Old 03-29-2014, 07:11 PM
My car weighs similar to a GTO.
Ive had 346, 383, 403 etc in mine, and none have ever been a pig low down regardless of size or compression.
If you're looking to make 1000+ on only 91 octane, I'd say keep CR around 8.5:1
Old 03-29-2014, 07:45 PM
Zero_2_Sixty's Avatar
My dynamic compression at 1000 is 9:1
Old 03-29-2014, 09:24 PM
MillsMotorvation's Avatar
Had mine at 9:5, on 22psi no problem, just added heads I will be at10:3 should be way better! Out of boost it was always strong.
Old 03-29-2014, 10:36 PM
MUSTANGBRKR02's Avatar
Mine will be around 9.5-1 on a 427 going for 1500.
Old 03-30-2014, 07:42 AM
Cam72aro's Avatar
9.5:1 on my 408, ls3 heads, 20psi e85 and methanol. Car runs very strong out of boost and is a monster in boost.
Old 03-30-2014, 12:24 PM
Sales@Tick's Avatar
Dynamic or static? 9:1 dynamic is really high IMO for pump gas and boost. Are you running race fuel?
Most of the combinations we build are 9.0:1-10.0:1 static depending on the goals of the customer.
IMO the cam used will be more important for "not being a dog" than the compression ratio used.
Old 03-30-2014, 12:26 PM
Sales@Tick's Avatar
Bill,
Are you planning on using a 427 with that 88mm from BEP?
I would personally build a smaller motor for that turbo, JMO though!
Old 03-30-2014, 01:27 PM
Freefallin's Avatar
Its funny how things snowball. Ppl don't usually mention DCR or SCR when they mention CR. So which one are they talking about when then say "im at 9.5:1 at 15psi".
Im guessing SCR.
Old 03-30-2014, 03:32 PM
F110Mech's Avatar
I would consider using methanol on top of the pump gas to have the ability to run higher boost
Old 03-30-2014, 04:31 PM
Dynamic or static? 9:1 dynamic is really high IMO for pump gas and boost. Are you running race fuel? Most of the combinations we build are 9.0:1-10.0:1 static depending on the goals of the customer. IMO the cam used will be more important for "not being a dog" than the compression ratio used.
I am running 93+meth
Old 06-25-2020, 10:30 PM
po feng's Avatar
93 fuel ?
Old 06-26-2020, 04:27 PM
6 year thread bump
Quick Reply: What compression ratio for 1000rwhp 408
