reman 4l60e damaged at dyno question
During a recent visit to the dyno shop, I broke/bent/twisted my driveshaft. When I went under the car for repair, I found other parts damaged. The tail housing cover was in 2 pieces. Also I noticed a crack in the cover area around the output shaft just behind the tail housing cover. Not sure what that part is called. My question is how should I go about repair? Is the cracked part a separate part that can be removed and replaced or is it part of the full outer cover? Any help would be greatly appreciated!!
Driveshaft slapped the wall inside the driveshaft tunnel. I think that's what caused the crack. Probably was a pretty violent side shock to the output shaft.
Moderator
Yeah, the trans case is toast.
I have always been very satisfied buying large parts from ebay seller "powertrainpartsplus". They have a few late-model 4L60E cases available right now for $60 plus shipping. Output shaft is $33. They also have tail housings.
You should try to determine what broke first - was it a U-joint?
I have heard of the torque arm cracking the tail housing which might have started a chain reaction.
If you are looking at 600+HP in the future, JoeNova's suggestion should be seriously considered; there are lots of threads here on that subject.
does that sound possible?
Moderator
I don't own a car with a torque arm and therefore cannot give you an experienced answer. It does sound "possible"; in any case repairing/replacing the driveshaft, trans case, trans tail shaft, torque arm and bushings should get it fixed. Of course all that is a very expensive fix.
Moderator
The stock steel driveshafts are prone to this, especially
when overspun (anything over 2.73 gears got aluminum
driveshaft from the factory). Don't know how a V6 drive
shaft relates to what came behind the V8 with 2.73s,
but expect no better.
Moderator
I just had a custom aluminum one made by shaftmasters.com (local to me, but recommended elsewhere on this site). They said it is good for 3000 ft/lbs which equates to 1000 ft/lb engine and a 3.0/1 1st gear trans ratio.
The car is super smooth with it; I suspect my previous custom steel one was a bit out of balance. Cost about $325.
