vacuum source for Bov?
Old 04-13-2014, 06:01 PM
70c10's Avatar
Default vacuum source for Bov?
Will this work for a vacuum source for my 60mm Jgs Bov? It says not to hook up to a source that will let oil flow into it. I don't think that it would be a problem using the brass barb behind the throttle body. Just want to make sure. Thanks guys
Old 04-13-2014, 06:10 PM
BTLBABY's Avatar
Yes, that will work just fine. Just make sure you put some type of clamp to hold the hose on so it doesn't blow off under boost.
Old 04-13-2014, 11:01 PM
70c10's Avatar
Also can I use the smaller 1/4 barb where the map sensor plugs into for my boost Gauge?
Old 04-13-2014, 11:19 PM
BTLBABY's Avatar
I don't see why not. You still going to run the MAP in the factory location?
Old 04-13-2014, 11:37 PM
70c10's Avatar
Yes it's a 2 bar from a cobalt.
Old 04-13-2014, 11:39 PM
BTLBABY's Avatar
Yep, you'll be good to go.
Old 04-15-2014, 09:48 AM
70c10's Avatar
Thank you.
Old 04-15-2014, 10:57 AM
STEEPSS's Avatar
For what its worth, you can cut that nipple off, and drill / tap it for 1/8" NPT and run a -3 or -4 fitting off of it. Thats what I'm doing for my fuel pressure regulator. Also, I tapped the larger hole for a 3/8 NPT nipple, and my MAP will be located just a short distance away.
Old 04-16-2014, 08:22 AM
toytech93's Avatar
Since we're on the subject,
- Can a BOV and a WasteGate share a reference line ?
I'm thinking of using a T-fitting in the top of my BOV.
Old 04-16-2014, 08:40 AM
killernoodle's Avatar
I wouldn't. Any thing that is potentially a (even small) boost leak shouldn't be on the sensor. That 1/4" line on the end of the manifold next to the MAP port should be a good one for all your boost/vac reference lines. Keep the big ports for your WG/BOV/Catch can.
Speaking of which, I changed my vac lines around to have my BOV and my catch can share the same 3/8" vacuum port on the and my BOV stopped working right. Apparently the vacuum source was no longer strong enough with the leak to the catch can.
Old 04-16-2014, 04:30 PM
toytech93's Avatar
well, that makes sense. the catch can is a constant controlled leak. I'm thinking the BOV and WG won't be a problem sharing a line from a 3/8npt port on the back of a holley hi-ram.
Hoping someone already tried this and will drop their .02 in here.
Quick Reply: vacuum source for Bov?
