Expansion tank
Old 05-07-2014, 04:02 PM
oscs's Avatar
Default Expansion tank
does anyone have a source for an affordable Expansion tank? like under $100 shipped affordable? Im unsure on the appropriate size to use and only want to do this once.
Ive read that the 1qt or 1/1/4 qrt is good but i wanted to hear from some of you that have used one. I found this one for cheap but am afraid it is too small..
http://www.racingpartdepot.com/servl...pansion/Detail
Old 05-07-2014, 08:12 PM
oscs's Avatar
no one runs an aftermarket expansion tank?
Old 05-07-2014, 08:47 PM
ws602's Avatar
I run a canton tank pm me your email for pictures
Old 05-07-2014, 09:26 PM
Gingervitis Addict
slow67's Avatar
LS1Tech 10 Year
I have a friend running the Moroso expansion tank.
Old 05-08-2014, 01:03 AM
8 Second Truck Club
Blown06's Avatar
Dude, how can you price anything if you don't even know what dimensions you need? Figure out what you need, then shop.
FYI, I'm running a 6 qt expansion tank on the truck. I run one that big cause when it pushes water......it pushes water.
Old 05-08-2014, 05:46 AM
JAX04's Avatar
Heres mine from Summit, Its a Howe tank and i have it running to a large overflow under the core support incase of push.
Old 05-08-2014, 07:43 AM
oscs's Avatar
Originally Posted by Blown06
Dude, how can you price anything if you don't even know what dimensions you need? Figure out what you need, then shop. FYI, I'm running a 6 qt expansion tank on the truck. I run one that big cause when it pushes water......it pushes water.
Well if you read my post I also ask the question on what size to use..
Old 05-08-2014, 07:44 AM
oscs's Avatar
Jax I've seen that one before, do you know what size it is? Doesn't look very large.
Old 05-08-2014, 07:45 AM
oscs's Avatar
Do you know which size he is using? I believe they sell a 1qrt and 1.5
Old 05-08-2014, 09:44 AM
JAX04's Avatar
It, in itself, is not very large. however, That eliminates the remote fill, and i use a larger hidden overflow tank from there. the bottom outlet goes into the 1/2" npt heater port, the steam vents go to each side of it. If it overflows, it runs down to a large overflow tank under the core support, i have been considering running it to the trunk and putting a large clear container back there to measure it better, should it push water.
Quick Reply: Expansion tank
