The Vinci spring tool is the shit
Originally Posted by foff667
comp makes one that is VERY similar to your design but more expensive FWIW
It looks like the groove cut in this particular tool would help keep the spring aligned properly when compressing.
Thanks,
Derek
The grove side is for spring that sit higher. You need to use this side to get the nut started. Our first spring the nut started to wear but after we dropped in in some rear end oil everything was good to go
Originally Posted by Richie Carbone
It is the new comp tool. Vinci just sells it.
haha... "dual larry tool".
I'm looking forward to using mine soon.
This Vinci one looks like the best I've seen. Cheaper than all of the 'fancier' spring tools too.
