best wideband for HP Tuners?
What is the best wideband to measure AFR that integrates with HP Tuners? Our rear O2 sensors have been disabled (no cats) so I'd like to pull them, plug one, and use the other for a wideband to measure air fuel both on NA and nitrous passes. Not really interested in something with a gauge just a kit that will allow me to scan AF into HP Tuners. Which one has the best ease of installation but more importantly will be accurate and allow us to tune?
Thanks.
Scott
Thanks.
Scott
You're going to get all kinds of opinions on what's the best wideband and a lot them based on no facts. As far as hooking up to HPT they will all hook up about the same. If you buy one of the more popular ones its already loaded into HPT and you can select it vs making a custom PID to log it.
With any wideband and nitrous tuning I recommend reading your plugs and just using the a/f on your wideband as a reference.
The plugs looked good on the dyno; we had the timing mark just on the bend of the strap on the plug. I realize though that real-world racing is different and we'll have to watch it there too.
Scott
Thanks!
Scott
Plugs show AFR? I'm new to nitrous and trying to take our time, learn, and make horsepower safely. I thought the timing mark showed if you had enough timing pulled. How do you read plugs for AFR? We had the AF correct on the dyno; doesn't that ensure it will be right at the track?
Thanks!
Scott
Thanks!
Scott
You'll need to cut the threads off the plug in order to see the fuel ring. Its at the base of the porcelain basically making a circle all the way around. It can look anywhere from almost white (really lean) to looks like a black marker (really rich) Reading your plug's will be more accurate than using a wideband for sure. Also depending on what kind of dyno you were on, load bearing for inertia only your a/f and timing could be a good bit off real world.
Here is a old article on plug reading
http://www.dragstuff.com/techarticle...-pictures.html
Scott
