Running out of pump??
Old 05-25-2014, 07:37 PM
slvr T/A's Avatar
Default Running out of pump??
01 T/A with some AFR 205s, 230/232 cam, stock LS6 intake and TB....Red top injectors. Been running it on motor for a while now with no problems. Added 100 shot through a nozzle with some NOS noids that i've had sitting around and I can't get the Air/Fuel right. It has a stock fuel pump. Sprayed it with the recommended 100 jets and it was lean. Upped the fuel jet some. Lean. Upped it even more. Still lean. It will be OK down low but at high RPM it goes lean like it's running out of fuel. Even put 50 shot jets in it and it's still needing a bigger fuel pill Am I just at the limit of this stock pump or is there another problem I need to look at?
Old 05-25-2014, 08:37 PM
The Scammer Hammer
dr_whigham's Avatar
Wet shot or dry?
Either way, you really need some 42's for that even on just motor. My 42's were at 77% in the Camaro. You've GOTTA be maxing those red tops.
Old 05-26-2014, 07:11 AM
slvr T/A's Avatar
Wet shot. Injectors are at about 90% duty cycle
Old 05-26-2014, 09:22 AM
Z28 MIKE's Avatar
i would say its the stock fuel pump. I have seen heads and cam cars run out of fuel on stock pump before.
Old 05-26-2014, 03:02 PM
The Scammer Hammer
dr_whigham's Avatar
Should have put that in my original post as well: definitely get the Racetronix kit with the Hotwire upgrade. The stock FP will taper off a bit at WOT, and if you're pulling your shot from the fuel rail... You see where I'm going with this.
Old 05-26-2014, 04:25 PM
Footlead's Avatar
Running out of Fuel..... stand alone is your friend or some 42lbers... Race car!
Old 05-26-2014, 04:50 PM
slvr T/A's Avatar
Thanks guys, going to put a 255 in it this week. Footlead i'm just trying to be as fast as you!!
Old 05-26-2014, 07:08 PM
HCI2000SS's Avatar
Good move on the 255 pump op! Yes, that stocker was extremely maxed at that point lol
Old 05-26-2014, 07:54 PM
9 Second Club/Nitrous Mod
shortdog's Avatar
Pull plugs and make sure nothing's hurt.
A H/C nitrous car will need a 255 pump AND bigger injectors like stated. You will need a tune for the injectors.
A racetronix can usually take 600+/- hp. Get a standalone if you decide to spray 200+ in the future.
Old 05-26-2014, 07:59 PM
slvr T/A's Avatar
Nothing is hurt. Every time it went remotely lean on the wideband I shut it down. Would it be ok without doing the hotwire harness and just dropping in a 255 pump? The red tops are getting the job done for now (90% duty cycle).
Old 05-26-2014, 08:23 PM
The Scammer Hammer
dr_whigham's Avatar
Don't skimp on that. It's 49 bucks, and WELL WORTH it. The pump requires more voltage. Look to WS6store for the best price...
Old 05-26-2014, 08:26 PM
shortdog's Avatar
A hotwire harness and 255 pump should work.
Aren't red tops only 30lbs? (not much over stock)
90% duty cycle is a little high for my taste.
Old 05-27-2014, 09:22 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
Needs more pump! You could also add a safe tank specifically for the nitrous system as well.
-Garrett
Old 05-27-2014, 05:59 PM
slvr T/A's Avatar
I want to say red tops are 36lbs--I have the 255 and hotwire on my car AND a stand alone fuel system on my car lol--(this thread is about my dad's T/A) I was asking about not doing the hotwire kit because my friend has a 255 pump he is giving me and I was just going to throw that in and be done with it
Old 05-30-2014, 07:21 AM
slvr T/A's Avatar
Update-- Car was DEFINITELY out of pump, lol. Installed a 340 pump and now it's rich on motor!!! So the car needed more pump even on motor and we were trying to spray it.. Getting the motor tune fixed then going to spray it!
Old 05-30-2014, 11:20 AM
The Scammer Hammer
dr_whigham's Avatar
Which 340 did you go with, if you don't mind me asking?
Old 05-30-2014, 01:20 PM
Glad you were able to find the issue!
-Garrett
Old 05-30-2014, 05:28 PM
slvr T/A's Avatar
Aeromotive stealth 340. Super quiet too
Quick Reply: Running out of pump??
