How many guys ONLY run off the Wastegate spring
That's all I'm doing at the moment. I will add some sort of controller down the road but for now it's working. Just keep an eye on your gauges when driving, just incase you have boost spike, fueling problem. I'm sure some will say your crazy for not having a controller of some sort, but I'm not worried about it
Nothing wrong with it if you are happy with a single boost pressure. It's probably the most simple and reliable option by far, and certainly the cheapest.
And there is a controller...the wastegate and spring/pressure signal technically are the controller
I run WG spring pressure alone at the track. I have a ball valve in line with my EBC on the bottom port. I close it at the track and that nets me 20lbs. Open the valve and I slowly ramp in boost with RPM to 17lbs for street driving with the EBC. Works great!
Then I have another adjustable regulator mounted in the car that applies pressure to the top port to add above 20lbs if I want to break things.
