How many miles do you XE-R guys have on your valvesprings?
Old 05-19-2004, 08:21 PM
Colonel's Avatar
Question How many miles do you XE-R guys have on your valvesprings?
Just wondering how far they've been pushed with these aggressive lobes.
What springs and what cam?
What type of driving?
What tranny and rearend gearing?
Thanks!
Old 05-19-2004, 08:50 PM
01_SuperSlow's Avatar
3000 miles
Crane dual springs and tit. retainers, G5X2 cam on a 112
Daily driver with the ocassional spirited run .
Old 05-19-2004, 08:51 PM
Colonel's Avatar
I'm at about 10,000 on mine now, btw.
Now, who has some serious miles?
Old 05-19-2004, 09:47 PM
Ryan02SS's Avatar
Colonel, I don't have an XER lobe cam but I think the TR cams use lobes that are around the same. Here are my valvespring test pressures after only 4800 miles on my C918s. https://ls1tech.com/forums/generation-iii-internal-engine/165867-c918-test-pressures-4800miles-tr224.html
Old 05-19-2004, 10:38 PM
Colonel's Avatar
Interesting. Thanks. I'd be interested in seeing how they would measure in another 4,800. Might be pretty much the same if the springs just "settle in" a bit to begin with.
Anyone else?
Old 05-20-2004, 12:57 AM
v8 ute's Avatar
I had a 234/238 108 630/630 lift cam. 4600 stall 3.9 gears.
It did 15,000 miles befor it leta spring go. It had about 60 passes on it and numerous "spirited" drives, as well as lots of highway/town stuff.
They were ISKY doubles 1.4something diameter (I can't recall part number etc. Very near on coil bind too.
I use the Comp Cams Doubles now, still XER lobe, I'll just change @ 10,000 now instead.
Old 05-20-2004, 01:43 AM
Colonel's Avatar
That's alot of lift, alot of gear, and alot of stall. Sounds like you drove it like I do too. 15,000 miles?!? That's VERY encouraging! Thanks!
Old 05-20-2004, 01:47 AM
52172's Avatar
You'all overexagerate!!!!!!!!!!!! A good set of dual valve springs are good for at least 30,000 miles!!!!!!!
Old 05-20-2004, 01:49 AM
Colonel's Avatar
In some setups with some springs I would agree.
Old 05-20-2004, 01:54 AM
52172's Avatar
what do you mean with some springs I am saying dual valve springs!!!!!!! There are only three main manufactures!!!!!! Comp,patriot,crane!!!!!!!!!!!!!!!!!!!
Old 05-20-2004, 02:01 AM
The Guy in MY 99TA's Avatar
three main manufactures???? comp, crane, and isky maybe. Where in the hell did you get patriot? No offense to their heads, but my valves train parts will be left up to the people that are the leaders in valvetrain technology.
Josh S.
Old 05-20-2004, 02:07 AM
Colonel's Avatar
I mean "with some springs", just like I said. Some, meaning, "not all." Evidentally not all since V8 ute said he only got 15,000 miles out of his (which I think is pretty good considering his setup and usage.)
Don't forget Ferrera and Isky (that's what V8 ute said he had.) There are different sizes/types within these manufacturers too.
"I am saying dual valve springs!!!!!!!"
This thread is not limited to spring type. It could be singles or duals. All duals are not created equally.
What's with all the "!!!!!!!!!!!!!!!!!" anyway?
Old 05-20-2004, 02:11 AM
52172's Avatar
I understand all that ****!!! I believe Patriot Gold dual valve springs should gain their reputation very quick. No ifs ands or but ts
Old 05-20-2004, 02:13 AM
Colonel's Avatar
****? What ****? U C ???
Too many ???
Old 05-20-2004, 02:15 AM
52172's Avatar
positive etoh if you know what that means!!!!!!!!!!!!!!!!!!!!
Old 05-20-2004, 02:18 AM
SidewayzOZ's Avatar
Do us a favor and dont post unless you have the information Colonel asked for. Im very curious as to the results of this thread, and no offense, but you have put forth nothing worth reading into this thread.
Old 05-20-2004, 02:24 AM
52172's Avatar
I"d like to add to the subject through experience. I have a buddy with a t/x speed cam 231/237 and dual valve springs "patriot" with around 30,000 miles and the high performance automobile is fast as ****!!!!!!!!!!!!!!
Old 05-20-2004, 02:28 AM
Colonel's Avatar
Well, thanks 54321, but let's try to stick to personnally owned "high performance automobiles". I'm not a big fan of secondhand information. Thanks.
52172's Avatar
Default Please don't post unless you are sure of your opinions! regardless of the colonel
I think the title said it all
Old 05-20-2004, 02:30 AM
Colonel's Avatar
Enough of the sillyness. Back on subject please.
