N/A tune is spot on... Do I need a nitrous tune?
Old 07-25-2014, 10:06 PM
btr
btr's Avatar
Default N/A tune is spot on... Do I need a nitrous tune?
Or is pulling timing with the lingenfelter unit ok?
Wanted to start with a 100 shot, and pulling 4 degrees on top my NA tune.
Old 07-26-2014, 03:07 AM
tyler ovel's Avatar
Pulling timing with a colder plug like a ngk Br7ef gapped at .30-.32 Should be good enough. The lnc-2000 is very easy to install like we mentioned in your other post.
Old 07-26-2014, 04:27 AM
btr
btr's Avatar
Thanks just paid a bunch for tuning, wanted to make sure I didn't HAVE to go back.
Old 07-26-2014, 06:22 AM
WE TODD DID's Avatar
You tune the nitrous system independently of the engine tune. The only thing you do with the engine is pull the timing back to where it needs to be when you're spraying. You make your nitrous adjustments with jet and pressure changes.
Old 07-26-2014, 10:59 AM
BSmiff's Avatar
Just pull the timing and let it eat. If your tune was spot on, then pulling the timing and getting a good clean hit of nitrous in there will be amplified.
Old 07-26-2014, 11:33 AM
HCI2000SS's Avatar
I agree with these guys. I run the LNC 2000 with 3 degrees pulled for a 100 shot.
Old 07-28-2014, 09:49 AM
Ls1tech & Truck Sponsor
NitrousExpress's Avatar
If you tune up is spot on, I would pull timing and go test it out. 100 shot is still a relatively small amount of nitrous, and as long as you follow the jetting recommendations you will be fine.
-Garrett
Old 07-28-2014, 11:09 AM
Dynospeed's Avatar
Do you know how much timing your running NA? As long as the nitrous is wired correctly and the noids are in good working order pull 4-5 degrees. I would alway pull a extra 1 or 2 on the first test hit an then you can always put it back in. Also make sure you have good bottle pressure. We recently had a car come in that the customer wired and installed his own kit and said the nitrous felt funny. Come to find out he had a crappy filled bottle.
Quick Reply: N/A tune is spot on... Do I need a nitrous tune?
