Any tricks for turning off ASR light after rearend install?
Old 08-31-2014, 09:18 PM
jc98ss's Avatar
Default Any tricks for turning off ASR light after rearend install?
just like the title says, i was wondering if there was any way to turn off the ASR light after my S60 install.....i already found a way to turn off the ABS INOP light (from another thread).....how did you guys do it?....if i have to i will pull the cluster out and either tape the light or bust the little led bulb, but i'd rather not
Old 09-01-2014, 12:20 AM
jc98ss's Avatar
anyone?
Old 09-01-2014, 07:24 AM
Pharcyde50's Avatar
Black tape
Old 09-02-2014, 11:53 AM
LopeyZ's Avatar
Well, have you disconnected the ASR/TSC computer thats mounted directly above the steering column? Gotta reach up under the dash and it can be a bit tricky to find but it's there. Seach for a picture of it for reference. Not saying this method will work but I have high hopes for you.
Old 09-03-2014, 07:37 PM
Orange Juice's Avatar
I have heard that you can pull the dash off and break the bulls or run a higher current through them to burn them out.
Old 09-03-2014, 09:11 PM
That's MISTER MODERATOR
Paul Bell's Avatar
Good question bad section to stick it into. This here is the external engine hangout.
Post your question in the gears & axles section and you'll get more & better responses.
Old 09-03-2014, 09:37 PM
Randolph Ziskey's Avatar
"i already found a way to turn off the ABS INOP light (from another thread)"
If I may ask which thread?
Old 09-03-2014, 09:41 PM
Think I found it....need to get my eyes checked..
https://ls1tech.com/forums/lt1-lt4-m...ash-light.html
Old 09-03-2014, 10:24 PM
Paul Bell's Avatar
Mr. Ziskey, it that the Warren Johnson Pro Stock car in your sig?
Old 09-03-2014, 11:12 PM
It sure is. Love that car!!!!!!!!
Old 09-03-2014, 11:16 PM
Paul Bell's Avatar
Me too! It's usually seen in black.
Old 09-04-2014, 11:35 AM
LopeyZ's Avatar
Don't believe that method applies to LS1 cars...
Old 09-04-2014, 01:20 PM
jc98ss's Avatar
this method only works for 1998 cars
https://ls1tech.com/forums/generatio...ash-light.html
i wasn't really sure which section to put it in
Old 09-04-2014, 02:33 PM
It's not mine! woo hoo!
demonspeed's Avatar
I'll take care of it -- moving to Gears & Axles...
Old 09-04-2014, 02:45 PM
Anyone know which method will work on ls1's? 99-02
Quick Reply: Any tricks for turning off ASR light after rearend install?
