Valve cover paint
Old 09-16-2014, 07:45 PM
LS1-Mike's Avatar
Default Valve cover paint
Can anyone recommend a paint for my valve covers. Looking to tackle it this weekend. Any particular brand that works well and holds up. Also a procedure or any tips.
Thanks
Old 09-16-2014, 07:55 PM
Bill2002's Avatar
I used the auto paint from auto zone. I primed them first, then the paint from auto zone, then sprayed some clear. I let them sit for a week before I drove the car and they have not peeled yet. And still look good. Hope this helps.
Old 09-18-2014, 03:16 AM
trevmust's Avatar
if you use high temp clear you can use just normal (auto) paint.
Old 09-18-2014, 10:02 AM
thunderstruck507's Avatar
I used black Krylon. Just regular plain old Krylon, no primer, no sanding, no clearcoating.
Just clean them well is the biggest thing.
Old 09-18-2014, 04:03 PM
leadfoot4's Avatar
I agree.
When I did mine, I used black crinkle paint, but same procedure.
Old 09-18-2014, 10:26 PM
trevmust's Avatar
My post about high temp clear is relevant for brake calipers too, you want to match your body paint on your calipers? high temp clear over the colour and it works perfectly
Old 09-21-2014, 08:06 PM
mkvamso's Avatar
I like seeing posts about people spending lots of time and prep on their valve covers.
I cleaned mine with some degreaser, painted them outside with 2.99 rattle can and bolted them back on.
They look perfect, and if they get messed up, I'm only out about 15 min of work to re do them
Old 09-21-2014, 08:27 PM
trevmust's Avatar
I'm just going to get carbon fiber ones for my LS Build.
Old 09-22-2014, 11:15 AM
mjs1012's Avatar
I used high temp paint and clear coat when I did my valve covers and they came out nice. I probably spent a good 2 hours cleaning them beforehand though.
Old 10-16-2014, 06:17 PM
05SilveradoSS's Avatar
What do you clean the with?, ive heard of using prep-all?
Quick Reply: Valve cover paint
