Having problem
Old 05-24-2004, 12:05 PM
LenoZ28's Avatar
Default Having problem
I just got some new bfg drags and went to the track.I was stalling at about 4,000 rpm and still boging.I didn't want to go any higher because it idn't want to break anything.I wanted to see how I can leave the hole with out boging.
I did manage a 1.97 60' but i know i can hit better.Any help on this.
Old 05-24-2004, 12:44 PM
2_wacko's Avatar
Is your car a A4 or Manual?
Old 05-24-2004, 02:27 PM
LenoZ28's Avatar
Default proble
My car is manual.
Old 05-24-2004, 02:36 PM
CamaroB4C's Avatar
Is it bogging right off the line or after you have let completely off the clutch?
Old 05-24-2004, 02:40 PM
2_wacko's Avatar
You need a aftermarket clutch to transfer the power more to the ground and give you a better launch. But then you might need a new rear end if your BFG's hook.
Old 05-24-2004, 02:47 PM
LenoZ28's Avatar
Default Problems
i DUMP IT OFF THE LINE IT BOGS AFTER I LET GO OF THE CLUTCH.THEN IT SLOWLY GAINS RPMS.
Old 05-24-2004, 03:11 PM
CamaroB4C's Avatar
That would be my advice, the stock gears also could be bogging you down also.
Old 05-24-2004, 03:20 PM
JakeY2KZ's Avatar
what psi were you running?
Old 05-24-2004, 03:40 PM
LenoZ28's Avatar
I Think About 20 Psi
Old 05-24-2004, 03:43 PM
2_wacko's Avatar
Try riding the clutch a little off the line or try not reving at such a high rpm,
Old 05-24-2004, 03:46 PM
LenoZ28's Avatar
I'LL TRY TO LEAVE THE LINE WITH A LOWER RPM AND RIDE THE CLUTCH.
I'LL SEE HOW IT GOES
Old 05-24-2004, 04:17 PM
JHTZ28's Avatar
I don't mean to insult you or anything, but you do have the Traction Control off (ASR - Camaro)? Thought I'd ask, sometimes it's the simpliest things.
Old 05-24-2004, 04:40 PM
CamaroB4C's Avatar
1998 = No Traction Control Option
Old 05-24-2004, 04:44 PM
LenoZ28's Avatar
Yeah I Don't Have An Asr Button
