StealthII Cam
StealthII Cam
Im hoping the Colonel will chime in. I just ordered the StealthII and valve train upgrade for a buddy. 02 Firehawk M6 with all the boltons. Stock heads. Question, what would be the ideal shift point for this combo? 6400? Any input would be appreciated!
Keep in mind that I have MTI stage II LS6 heads but I've found that shifting my Stealth II anywhere between 6600-6750 works best. This is with an SS4000 converter which has a shift extension of roughly 5300-5400 in this application. If a converter with a higher shift extension was used, spinning it up this tight would be of slightly less importance.
Originally Posted by NumberOneSled
The car in question is a 6 speed.
Chris
Chris
Experiment, start at 6400 and work you way up 50-100 RPM at a time (a shift light would be suggested.) When it goes slower, back off a notch.
