time for a stall
time for a stall
So its time to order a stall for my camaro its a 02ss I'm putting in a torquer v2 can 113lsa, full exhaust and a tb. I plan to add nitrous in a few months also I need a stall I need advice on what size stall and which brands are good to use.
Its not that, but a really good on motor converter wont work well on n2o and vice versa, generally speaking of course. You need to know the amount of your shot ahead of time so the converter is optimized for that IMO.
The hard part of selecting the correct converter is determining intended usage. Usually a nitrous application means tighter converter, but if you only spray a couple times a year, I would focus on a converter that makes the car run hard the rest of the time rather than have a turd when off the spray. If you spray often, consider the tighter converter. Just my .02 here.
-Brian
-Brian
