99 Z28 will not start
Old 02-22-2015, 06:01 PM
98z8uup's Avatar
Default 99 Z28 will not start
The started last night. Went to start it today nothing. The car has a new battery and I pulled the starter. It was good. The light come on and the radio and windows are working. I need some help.
Old 02-22-2015, 07:24 PM
98z8uup's Avatar
Also the only light come on in the dash area. Is the seatbelt light. The car will start if I turn the key and bump the starter.
Old 02-22-2015, 09:57 PM
big_g's Avatar
So... The starter is good, the battery is good, and you have power to the lights, radio, windows, etc. Then you say nothing happened when you turned the key, but then the next post when you turn the key and "bump the starter" something does happen... What exactly do you mean "bump the starter?"
Old 02-23-2015, 02:41 AM
98z8uup's Avatar
I mean I can start the car from the starter.
Old 02-23-2015, 03:57 AM
98z8uup's Avatar
I just went back out and started the car and notice. Once the car is started none of the gauges are working. I was thinking I may need to bypass the VATS on the car, but the videos I seen on youtube. There security light was flashing. Like I said none of my lights are working in the dash area.
Old 02-23-2015, 06:20 PM
98z8uup's Avatar
I still have no clue
Old 02-23-2015, 09:52 PM
jaxcam02's Avatar
post a video
Old 02-23-2015, 11:34 PM
98z8uup's Avatar
I will try to get one up tomorrow.
Old 02-24-2015, 12:00 AM
LLLosingit's Avatar
I would start by check fuses.
Old 02-24-2015, 01:01 AM
98z8uup's Avatar
I check all the fuses 3 times. They are all good.
Quick Reply: 99 Z28 will not start
