What size transcooler and where to mount it
Old 06-01-2004, 10:42 PM
BriancWS6's Avatar
Default What size transcooler and where to mount it
I'm fixing to order up the tci ssf3500 and a b&m transcooler as soon as I find out what size cooler to order. I had this size in mind, 6" x 11" x 1 1/2". Will this fit alright? Also when it comes in where do I mount it? In front of the radiator or what? Thanks alot guys.
Old 06-01-2004, 11:21 PM
heyitsTaJay's Avatar
go with a 24k cooler. it will slide right up infront of the air dam.
http://store.summitracing.com/defaul...mission+cooler
heres the install
https://ls1tech.com/forums/showthrea...g+trans+cooler
its really easy.
J
Old 06-01-2004, 11:50 PM
BriancWS6's Avatar
On order, thanks man.
Old 06-01-2004, 11:53 PM
glad i could help. make sure you have some sticky tires! you will never look at your car the same. TRUST ME!
Old 06-02-2004, 08:41 AM
CamaroCain's Avatar
a 1.75 60' on the stock converter with your minimal mods is pretty good, you should see some mid to high 1.6's easy. Good luck with the new mods
Lynda
Old 06-02-2004, 09:48 AM
2002 Trans Am's Avatar
search for "Dope install" not sure why its called that, but thats how I installed my cooler.
Old 06-02-2004, 04:58 PM
BriancWS6's Avatar
Lynda
That 1.75 60ft was my best ever, I don't know what I did on that run. I usually pull 1.9s on the ES100 Yokahamas.
Old 06-06-2004, 11:33 PM
lrk322's Avatar
I put my B&M cooler on the plastic directly in front of the radiator. It fit in there really well on the passenger side of the v support. I figured the air is flowing right there to the radiator so the plastic piece directly across from it must pic up some flow too. I cut out the back of the plastic where i mounted the cooler for some extra air flow.
Old 06-07-2004, 12:29 AM
HAMRHEAD's Avatar
Good info I was wondering the same thing.
Old 06-07-2004, 10:25 AM
ironworker's Avatar
I recently posted a different type of trans cooler/install (alterative trans cooler) I used a "frame rail" type cooler mounted near the bottom of the radiator using brackets that attach to the car using two bolts for the air dam. Pluses to this is the cooler is not attached directly to the radiator, the cooler lines can be routed around the side of the radiator, I think the install looks better, and best of all the cooler only costs $30!!
I have pics if interested.
Old 06-08-2004, 12:19 AM
Pontiacerator
RevGTO's Avatar
Post 'em. Or PM me. I haven't heard of this kind of cooler and am interested.
Old 06-08-2004, 05:38 PM
BigPlanTransAm's Avatar
good info!
