which welds fit without grinding calipers
I need to know this and if you have to use spacers etc. grinding the calipers is out of the question for me thanks
Originally Posted by WildBills WS6
If you get spacers you will be fine. I run my skinnies with spacers.
If you don't want to grind the **** out of your calipers, spend the dough on a set of Bogarts.
Originally Posted by Fast SS on TNT
Please tell me that you also use an extended stud with spacers up front.....otherwise you have less then 5 turns on the lug nut, and are inviting serious injury and death.
LS1TECH Sponsor
No I do not have the part numbers. Many of the sponsors carry these as well as Jegs and Summit. They are 12mm studs and are much longer than stock. I got mine from Billingsly.
LS1Tech Co-Founder
Okay...
Front:
15x3.5 Weld, 5/16 spacer, no grinding
Rear:
16x8, 16x9 Weld XP, no spacer, no grinding (but these rimes are 22-23 lbs)
no 15" weld product will fit in back with out at least some grinding
Front:
Rear:
Originally Posted by Special K '01 WS6
my draglite XP's hit the calibers in the back... 16x8
