help ASAP: Tranny lines; reverse thread or not?
Old 06-04-2004, 03:42 PM
99whitews6's Avatar
Default help ASAP: Tranny lines; reverse thread or not?
Im in the middle of the TC change and cannot get the hard tranny lines to turn. I HAVE removed the wire e-clips and they won;t budge. Also what size are they, i have tried 18,19 mm and 11/16 and 3/4 and its either not going on or too loose. Cresent as of now!
99whitews6's Avatar
Old 06-04-2004, 03:50 PM
Doc
Doc's Avatar
Stop! Read http://modernmusclecars.net/forums/a...p?do=tcinstall, Learn, Take it easy man, you will get it.
Old 06-04-2004, 03:57 PM
99whitews6's Avatar
wait, so they just pull out once the e-clips are removed? Every other tranny have needed to use a wrench. The write up is not that specific, it just says they should come out easy now. FYI: this is the write-up i have been using to do the install.
Old 06-04-2004, 04:11 PM
Doc
Doc's Avatar
Sorry about that It has been a while since I used that very write up to do my install. I am pretty sure I used a 1/2" or 13 /14mm combo flare nut wrench. The key is the flare nut type of wrench. It is a normal right hand thread tho.
Old 06-04-2004, 04:45 PM
John_D.'s Avatar
They are not reverse. I don't remember the size though....
Old 06-04-2004, 08:43 PM
10 Second Moderator
Torkman15's Avatar
Are you sure they arent quick disconnect type...you pull the clip then pull straight out and the line comes right off. My 97 Suburban had them...Kinda slick
Old 06-04-2004, 08:53 PM
ss rally red's Avatar
You should be able to remove the clips and pull the lines right out, you do not need to remove the fittings from the trans housing.
Old 06-05-2004, 02:38 AM
Blue2002SS's Avatar
I just did my converter install last week so I know for sure. you just pull back the bushing and then remove the e-clip once the clip is out just pull on the line and it will come right off.
