Heeeeeeeeeeeeeeeellllppppp
Old 06-24-2004, 10:21 AM
zamboxl's Avatar
Default Heeeeeeeeeeeeeeeellllppppp
ok here is the thing last night i was puting in the crank bolt to hold in the crank pulley the engine starts turning of curse so my friend puts in the drive shaft and at the end puts a metal pice to keep it from turning. The engine keeps truning however while the drive shaft is not. He lets go of the drive shaft and it now starts turning with the engine. At this point is seems that the clutch is sliping The engine and the trany are hooked together off of the car. My question is does the tranny, clutch need to be on the car with all the lines hooked into it for the clutch not to slip. aaaghhhhhhhhh help damnit this is pissing me off, heyJABERWAKI if you out there i could use your input here!!!!
Old 06-24-2004, 11:23 AM
zamboxl's Avatar
o come one naybody?? somebody??
Old 06-24-2004, 11:28 AM
P Mack's Avatar
I don't see why it would slip just cause the lines are off. You do have it in gear right? I guess you could always take the starter off and wedge something in the flywheel teeth.
Old 06-24-2004, 11:46 AM
zamboxl's Avatar
ooooooooooooooo crrrraaap iam gona have to drop the tranny again to fix it o man iam gona shoot someone just kiddign iam not, but iam getting there
Old 06-24-2004, 02:33 PM
zamboxl's Avatar
so why would my clutch be not grabing asuming it was install properly????????????????
Old 06-24-2004, 03:21 PM
P Mack's Avatar
I guess you could try backing the bellhousing bolts off and pulling the tranny away from the engine like half an inch. That should take any pressure off the pressure plate springs if there is any and let the clutch engage. If it doesn't engage with no pressure on the springs than maybe your pressure plate wasn't bolted to the flywheel right or maybe your clutch is fucked.
Old 06-24-2004, 03:32 PM
hourang's Avatar
what gear you in?
Old 06-24-2004, 03:40 PM
zamboxl's Avatar
Originally Posted by hourang
what gear you in?
all of them 1,2,3,4,5,6, reverse
Old 06-24-2004, 03:48 PM
zamboxl's Avatar
NO THE CLUTCH IS BRAND NEW AND I BELIVE THAT THE INSTALL WAS DONE CORRECTLY SO ASUMING IS NOT THE INSTALL ANY IDEAS ON WHAT IT COULD BE, KEEP IN MIND THAT IT IS NOT IN THE CAR IS JUST THE TRANY AND THE ENGINE ON THE FLOOR SO ANY IDEAS PLSS BEFORE I SHOOT MY SELF JUST KIDING, BUT REALLY IAM BOUT TO SNAP HERE
zamboxl's Avatar
oops sorry bout the caps was't yelling i just din't notice they where on
Old 06-25-2004, 01:00 PM
hourang's Avatar
this is what i did, remove the starter, get a big flat head screw driver, and have someone wedge it against the flywheel and the ground, then turn the crank bolt.
Old 06-25-2004, 01:15 PM
badhoopty's Avatar
theres a tool that i havent used in ages that actually locks onto the flywheel to prevent it from turning or makes it easy to turn iffya want. had a big handle with a spring loaded doohickey that grabbed the teeth on the flywheel. been a long time so i dont remember exactly how it worked, but i used it quite a bit on my old poncho, but that was an automatic and all i hadda do was simply remove the inspection plate to use it.
Old 06-25-2004, 02:53 PM
zamboxl's Avatar
i already took care of the bolt my concern is that the clutch is not grabing at.
