A completely subjective cam question
I know this is a question that everyone has a different answer for, much like header and exhaust choice. I want to put a 224/224-112 cam or even one of the new 225/225-112 in my car. I have to keep in mind that someday in the next two years or so I will be back in CA where the car is registered and will need to pass the sniffer test again. What is my best bet going this route? G5X3, TR, TSP, guide me oh wise ones of the LS1 internals...
Originally Posted by Magred2001vette
For CA TR224 114 is on the edge of passing. I have a comp 224/224 .581 112 and with LT's and strait pipes it sounds like nascar at full throttle, but at idle a mild lope
I think it mostly depends on ramp rates (and LSA), once you get over 220-or-so degrees of duration.
A very lazy 220/220 114 could fail the sniffer, while a very quick 225/225 114 (maybe higher) may pass.
The TR cams have very quick ramp rates... and low overall duration.
Does anyone know of an exact degree of overlap, maybe at advertised and .050 duration, that would be a cut-off point for emissions?
The more I think about it, I think that's what it all comes down to.
The more negative degree of overlap the better chance to pass.
A 224/224 114 = -4
A 224/224 112 = 0
A 225/225 112 = -1
A 225/225 114 = -3
The 224 114 would have a better chance (these are aproximate calculations)
A 224/224 114 = -4
A 224/224 112 = 0
A 225/225 112 = -1
A 225/225 114 = -3
So I could get away with 224-114 or 225-114 at best. That leads to another question of which company makes the quick ramp rate that would be the best for me? I would like to improve my 1/4 mile time (who wouldn't) but I want it to sound the way a Camaro should on the street, I also am getting into SCCA again and this Camaro will be the one set-up for it. So excessive power although fun, is not totally neccessary.
Comp XE-R lobes are about the most aggressive available. An off the shelf XER 224/224 .581 .581 114 would be a great candidate. The TR224 runs a close second, IMO...slightly less lift at about .560". You can even find these cams used on here for under $300, since lots of people are into "big" cams. You'll get a nice lope at idle with minimal "cam issues".
Pass Cali Emissions
Sound like stock
Kick *** performance (420+rwhp)
You are looking at the perfect candidate
MTI SSII 224/220, .581/.581 116lsa
