when cam was installed i purged my AC..now what?
Old 06-28-2004, 08:08 PM
SSactionLs1's Avatar
Default when cam was installed i purged my AC..now what?
I got a can of 134, now what do i have to do? i dont need to flush it, just add so i can use my AC in this 100degree heat
Old 06-28-2004, 10:26 PM
TT-TECH Veteran
Inspector12's Avatar
1.5 LBS of R134.
Old 06-28-2004, 10:29 PM
2xLS1's Avatar
Pull a vacuum on the system and fill with (2) 12oz cans. I do it all the time.
BTW that = 1.5 lbs
Old 06-28-2004, 10:31 PM
how can i make sure i dont put too much in? i didnt purge much
Old 06-28-2004, 10:57 PM
2xLS1's Avatar
If you didn't release all the freon, why did you release any?
Old 06-28-2004, 11:00 PM
I didnt know how to move the AC condensor so i tried to unbolt it, it purged for a few secs till i closed it... It wasnt on purpose.
Old 06-28-2004, 11:13 PM
2xLS1's Avatar
If you live in a high humidity area like we do in Okla, you can charge it until you get condensation on the accumulator and be pretty close. Freon is less than $3/can around here so if it were me, I'd release it all and pull the vacuum and add the 2 full 12oz cans. It helps to have the vac pump and manifold gauges like I do though. Your only other alternative is to take it to a shop where they have a recovery machine and have them recover what is left and then inject the proper amount.
Old 06-28-2004, 11:15 PM
thanks alot man, what does that cost normaly?
Old 06-29-2004, 07:38 AM
SStillSSmokin's Avatar
I don't mean to hijack, but, I've been wondering about this. All the cam install writeups I've seen say you need to purge the AC. Why do you have to purge it? Is it just to give you more room to work? Or is it actually required?
Thanks!
Old 06-29-2004, 08:21 AM
1fastWS6's Avatar
Thanks!
You don't. Just rotate the condenser down slightly until its out of the way for the cam to slide over the top. Don't know why anyone would purge it.
Old 06-29-2004, 08:46 AM
That's what I thought. Hopefully I will get to do a cam swap soon!
Thanks!!
Old 07-04-2004, 07:31 PM
TT-TECH Veteran
Cost me about $45 for a friends car.
Old 07-05-2004, 04:43 AM
Tom@SpeedInc's Avatar
so you tapped the schreader valve and let some gas out? I wouldnt' top it off. I'd go to an independant shop and get a evac and recharge, probley needs it anyway. Atleast then its going to have proper charge, oil and be evacuated properly for probley $45-60 bucks.
