Oops, wrong oil!
Old 07-10-2004, 05:30 PM
MikeMs01TA's Avatar
Question Oops, wrong oil!
I was in a hurry to leave just now, and accidentally poured a half quart of Mobil1 0w-20 full synthetic oil in my T/A. I'm guessing it won't hurt anything, since I run Mobil1 5w-30 normally, what do you guys think?
Old 07-10-2004, 06:02 PM
WS6WRX's Avatar
no worries, it's still oil so you have nothing to worry about.
Old 07-11-2004, 04:06 AM
Patman's Avatar
Just top it up with a 1/2qt of Mobil 1 15w50 right now and you'll be fine.
Old 07-11-2004, 02:03 PM
MikeMs01TA's Avatar
Thanks for the comments, I just freaked due to the forehead slapping moment
Old 07-11-2004, 03:18 PM
cyphur's Avatar
I did this w/my 280z during a flush process....follow patman's advice and you're good to go!!
Old 07-11-2004, 07:21 PM
2001CamaroGuy's Avatar
Only do this if you have space (you are under the fill mark). DO NOT go over the fill mark as this will cause LOTS of windage problems.
I would say just go drive it and next top off use thicker.
Old 07-12-2004, 03:50 AM
Patman's Avatar
Not true, the LS1 can handle an extra quart of oil no problem, in fact GM recommends it for those that road race! Many people on this forum run extra oil, I've heard of a number of them which even go as much as 1.5 quarts over with no ill effects. With some types of engines you can't do this, but in the LS1 there is enough room that this extra oil is not a problem.
Old 07-12-2004, 10:50 AM
.....ok....go for it......
I went over by a quart once and had a number of problems till it burned/leaked back down to the full mark (clouds of smoke, pushed the front main seal out, popped the dip stick up).
I'm not going to tell anyone they are wrong but I personally would not/will not do it.
Old 07-13-2004, 03:51 AM
Patman's Avatar
And this happened in your LS1? Like I said, tons of guys out there run 1 to 1.5 over in the LS1, with no ill effects. Just as mitchntx, he's been running 7qts in his 98TA when roadracing, since the car was new, and he's got over 90k on his motor now.
Old 07-13-2004, 08:51 AM
yep
Old 07-13-2004, 10:08 PM
camaro98z28's Avatar
This is 2001camaroguy aka "Mini" we are talking about..
Old 07-13-2004, 10:45 PM
Racehead's Avatar
I run 3/4 of a quart over full all the time and don't have any issues at all. This includes street driving and ORR.
Old 07-14-2004, 01:00 AM
1999Z28's Avatar
i put the big filter on and 6 qts
