I Have a Problem ! Please Help !
All of a sudden, my oil pressure has sky rocketed to over 100 1bs . What can be the cause of this ? I checked the oil and it seemed fine . I'm not driving it now, but do you recommend I drive it to see if it will smooth itself out ? I need help fast !
I've seen senders send erratic signals as well as low and high signals. If there is a short or the sender closed it would send a really high signal.
If you turn the key to on ( not start), does the oil pressure gauge read 0 or 100?
So you're saying that the gauge reads 80psi before you start the car, correct? Then it's definately a sender/wiring problem and you're oil pressure might be normal and safe to drive.
