9" center section question
It seems that there are 3 center sections
Stock center section?
Nodular iron center section. Good for street/strip
Aluminum center section. Good for strip.
I have a detroit locker with 4.10 gears and a stock center section. Is this going to hold up on a bolt on/cam 6 speed car or should I get a Nodular iron or Aluminum center section?
TIA
TIA
Originally Posted by jswhite
With a 6-speed I would go with a aftermarket nodular case at the very least. You can get a Strange case for a little over $200.
There are also:
Alum Bolt Through Cases
and Magnesion Cases
Check out:
www.markwilliams.com he has all the goodies =0)
and Magnesion Cases
Check out:
Originally Posted by badpewter-z
Aluminum here and street driven regularlly
no problems yet , hopefully it won become an issue, the car sees street and strip what have you read bad bout it for the street?
Originally Posted by BTL FED
There are also:
and Magnesion Cases
Check out:
and Magnesion Cases
Check out:
