how much shaving to get 6.0Ls to 67ccs
Old 08-15-2004, 01:33 PM
taqwache's Avatar
Default how much shaving to get 6.0Ls to 67ccs
aproxemently how much should i surface my 6.0L heads inorder to get 67ccs. also keep in mind that this is going on a pretty heavy nitrous motor so i dont what to go too much.
Old 08-15-2004, 01:47 PM
Suspended Sponsor Account
ForceFed HP's Avatar
IRC it will take about .028 to bring the 71cc down to 67. it takes approx .007 to remove 1cc from an LS1 head, so .007x4=.028
Old 08-15-2004, 02:00 PM
taqwache's Avatar
IRC? what is it short for? also considering that an LS1 head has a different style of chamber then the 6.0L wouldn't that formula me kind of off.
Old 08-15-2004, 04:14 PM
IRC should have been IIRC(if I recall correctly). the 5.7L and 6.0L have the same basic combustion chamber design other than the obvious difference in cc size and the 6.0L is setup for a 4" bore. basic rule of thumb is .007-.008 of milling equals 1cc.
Old 08-16-2004, 11:23 AM
gonzo 6.2's Avatar
Q: for Brad or some other sharp cookie. If you had a 6.0 Lq4 (9.4comp) and bolted on a set of untouched LS6 heads,what would the compression ratio be?
Old 08-16-2004, 11:56 AM
taqwache's Avatar
thanks man. i will probably go .030 on them then.
Old 08-16-2004, 12:05 PM
PREDATOR-Z's Avatar
Call a sponsor and get the right numbers. The last thing you want is shave too much or not enough. Also you have to be careful with PV clearance depending on the cam and valves you are running. Also you would have to specify head gasket used and thickness.
I would get a professional opinion, perhaps a couple if I were you.
Old 08-16-2004, 10:04 PM
taqwache's Avatar
Awsome, i just called TEA and they said the same thing ".030". Also they can shave and cc them for $100. i just might send them over to them. the pistons should clear since they have pretty good releafs in them but i will just have to check it out when i get it all together. thanks.
