how much shaving to get 6.0Ls to 67ccs
aproxemently how much should i surface my 6.0L heads inorder to get 67ccs. also keep in mind that this is going on a pretty heavy nitrous motor so i dont what to go too much.
Suspended Sponsor Account
IRC should have been IIRC(if I recall correctly). the 5.7L and 6.0L have the same basic combustion chamber design other than the obvious difference in cc size and the 6.0L is setup for a 4" bore. basic rule of thumb is .007-.008 of milling equals 1cc.
Originally Posted by taqwache
thanks man. i will probably go .030 on them then.
I would get a professional opinion, perhaps a couple if I were you.
Originally Posted by PREDATOR-Z
Call a sponsor and get the right numbers. The last thing you want is shave too much or not enough. Also you have to be careful with PV clearance depending on the cam and valves you are running. Also you would have to specify head gasket used and thickness.
