What cam to go with??????????
Old 08-16-2004, 01:47 AM
WildBills Toyota's Avatar
Default What cam to go with??????????
If I keep my car Ill look to do a bigger cam. I want 440+ stock heads. I know these 3 cams will do it.
trex
g5x3
magic stick
What should I do guys. These cam are all around similiar size specs. I would like to keep it on a 112 or 113. Let me know
Old 08-16-2004, 01:58 AM
jrp
SN95 Director
jrp's Avatar
you wont get that 440+rwhp through the 12 bolt, gears, and drive shaft. you want that number invest in some heads.
Old 08-16-2004, 02:05 AM
Z28Venom's Avatar
Yep..
If you're looking for 440+ you're definitely going to have to invest in some heads...
Or a little juice on top of one of those
Old 08-16-2004, 10:01 AM
Trevor_00Ws6's Avatar
just get some heads... You will have much better streetability and will have closer to the numbers you are looking for.
Old 08-16-2004, 05:30 PM
heads are $$$$$
Old 08-16-2004, 08:10 PM
jrp
SN95 Director
jrp's Avatar
Originally Posted by WildBills WS6
heads are $$$$$
well then lower your expectations.
Old 08-16-2004, 09:04 PM
ls1hybrid's Avatar
damn jrp, tell it like it is...jk
if you get the magic stick you could always sing that song
"i got the magic stick....i know if i can it once, i can hit twice...."
Old 08-16-2004, 09:09 PM
O2bqwik's Avatar
either one is a good choice but i highly doubt your gonna get 440rwhp with a 12 bolt with 410's. good luck either eay
Old 08-16-2004, 09:14 PM
LG Motorsports's Avatar
Hi we have a special on for the AFR heads and our G5 X-3 cam. We use the Comp 921 springs with the AFR heads and mill them for the correct compression. That package is $2995 for the complete heads, G5x series cam and pushrods.
This will get you over 440, and probably over 450rwhp.
Thanks and give us a call
Lou Gigliotti LG Motorsports
972-272-753
Old 08-16-2004, 09:18 PM
Scalpel's Avatar
The G5X2 and X3 are two of the nastiest all around performer cams. With proper tuning they cause no driving issues except GOBS of power!
