Bolt on performance mods
Looking to make a list of them all. Everything you can do to a car to make it faster in the quarter. Weight reduction doesnt need to be in here but stuff like short belt and front sway bar can. Figure it would be a great way to help out the new comers and also help me have everything done before i start swapping motors later on some day.
Cat back
Headers
Y pipe
Remove front sway
Slicks and skinnies
Air box lid
LS6 manifold
AC short belt
Underdrive pullies
A arms and K member
Hal shocks
160 degree thermostat
torque converter or clutch
Rearend gears
manual steering rack
Air filter
MAF
Relocate battery to trunk
I know i am missing a ton more so anyone please help me.
<small>[ February 12, 2003, 12:31 AM: Message edited by: sited12 ]</small>
Cat back
Headers
Y pipe
Remove front sway
Slicks and skinnies
Air box lid
LS6 manifold
AC short belt
Underdrive pullies
A arms and K member
Hal shocks
Rearend gears
Air filter
MAF
Re: Bolt on performance mods
-ported TB
-ram-air induction of some type (recommended if not WS6), i.e. Fast Toys Ram Air
-high-flow bellows
-lots of suspension stuff
-merge collectors
-true dual exhaust conversion
-hacked-up airbox for more airflow
-TB coolant bypass
-EGR mod
-electric water pump
-tuning via one of the 8 million methods we have now
-lighter driveshaft (careful not to sacrifice strength)
I'm sure I've missed some as well. But, there's a few more for ya. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Also, FWIW, the A/C is driven by a separate belt than the other accessories. The "short belt" most of us refer to bypasses the power steering. You can just remove the A/C belt completely (if not the whole A/C system <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> ).
-high-flow bellows
-merge collectors
-TB coolant bypass
-EGR mod
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by kent:
<strong> Base on review of your list you are well on the right track. I would suggest Hal drag springs and a port and polished throttle body. I would work on the suspension first and then move to the Bolt-ons on the motor. Also, a good tune can give you additional performance. Good luck in your quest. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I havent done them all yet but i am planning on them. I want to get my whole car set up and run 11.3 if not lower as a bolton car and then the only thing left would be to drop my motor in that i am building. Thinking of building something like BeaSSt's 436 if i can sneak a small amount of information from them. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Oh, well, I'd go edit it if I were you. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I already mentioned the electric water pump, that's why I didn't guess you were referring to it.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by sited12:
<strong> I want to get my whole car set up and run 11.3 if not lower as a bolton car and then the only thing left would be to drop my motor in that i am building. Thinking of building something like BeaSSt's 436 if i can sneak a small amount of information from them. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">an 11.3 as a bolt-on car in Chicago?? WOW! <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> I would definitely be impressed with that. Best of luck to you. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
later,
Steve
later,
Steve
Dont worry there will be alot of weight coming out of the car for that. K member, A arms, manual rack, fiberglass hood, skinnies. I have the whole weight reduction list saved and whenever i do something on the list i delete it so it will weigh alot less. Got all summer to pull the funds and time together to go for my goal.
Not sure what it runs now. I had 2.73 gears and now i have 4.10s. Also going to put a PT 4400 converter and delete torque management. But with basically headers, loudmouth, lid, 160 thermo, and HPP3 along with ET streets i ran 13.0 So i am thinking with the gears and a torque converter i should pick up a whole bunch. And the car is a 2000 so LS1 intake and the older cam.
Thoes ET Streets may have been hurting rather than helping. ET Streets are way too much tire for 2.73s and stock 'verter IMO.
I was able too dead hook w/a street tire and 3.23s before the converter.
yep, i went 11.74 @ 114mph w/ 1.56 60ft. for bolt ons... That run was at GLD on a perfect day. i think i was right at or under sea level for DA and on a day that GLD was hooking GREAT.
MODS:
TP4400
Lid
Hooker LT headers
12" extensions off the headers into Flowmaster 1-Chambers dumped under the front seats
3.23 gearing
skinnies
26x10.5x16 ET Streets on 16x8 Weld Draglite XP's
shift point adjustments/TM removal/rev limiter adjustments
tubular LCA's
That's it, oh yeah, weight reduction <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> My car weighs right in at about 3200 w/ me in it. I weight 165lbs. I have a lot of stuff out of the car, but there was so much more i could do too. LS6 intake, ASP pulley, MAF ends, ported TB, was going to do 4.10's/28" tire, tubular k-member/a-arms, suspension stuff, etc...(and the more I look at the list that you guys have put together, i realize how much more stuff there was i could have done... DAMN i wish i was still building that car)
You can get there. Just need to follow what the others have done and go from there. US41 would probably be a better track to hit your goals at, but you can always try everywhere else. I was well on my way before my shortblock blew(rod bolt). Good luck!
Chris
PS- my weight reduction was, well, not typical, but definitely NOT to the Extreme. here's my little website to give you a little more reference on what was taken out.
My Webpage
<small>[ February 17, 2003, 07:30 PM: Message edited by: z28kid98 ]</small>
MODS:
TP4400
Lid
Hooker LT headers
3.23 gearing
skinnies
tubular LCA's
Chris
My Webpage
Thank you that helps me out alot. The thing i noticed was the 1.56 60ft with 3.23 gears. I have 4.10s so the car will 60ft pretty good. I admit with nittos i would of had a 12 second pass but it was the end of the season and i got an incredible deal on the ET streets so i went with them. I noticed that you had barely done any power mods it all seemed to be weight reduction and drivetrain. I like that there is alot of room after what you have accomplished. Bummer about your car. Im sure after going through that it would be really cool to make another run at it sort of like the Colonal is doing.
yeah, barely any power mods because not alot of money <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> all in the lightweight car, huge converter, and good traction/weather. that's pretty much how you get ahead in the bolt on game.
Chris
Chris
if you only went 13.0 with those mods, youre gonna need a lot of help to get you to 11.3s with boltons. i hear thats a good converter, but i still think youll be short unless your car weighs 2600 pounds <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
fwiw, my car went 13.2 with 2.73s and a lid.
