Voltage limitations of TPS and "PE" mode issues (FAST intake & TB)
Old 09-01-2004, 09:14 AM
Super Moderator
Reckless's Avatar
Default Voltage limitations of TPS and "PE" mode issues (FAST intake & TB)
We ran into an issue yesterday with excessive TPS voltage on a car with the FAST 90mm intake and TB. Car threw a code for high voltage. On the A/F graph, the car would be fat upon rolling onto the gas, but when we went WOT, the A/F would spike to 14.5:1 and stay there.
We figured out the excessive voltage with the TPS was causing the PCM to exit the PE tables or something similar. We had to "finagle" the TPS sensor so it would max at 4.7V, and then the issue was resolved.
I don't have a Volume 2 for my Helms manuals, but was curious what it says about the voltage limitations of the TPS sensor and what the effects are if the high threshold is exceeded?
Old 09-01-2004, 11:47 PM
383838's Avatar
It's very similar to what happens when people grind too much off the stock throttle body's bump stop. 5.0V is the absolute limit, but since voltage is not constant 4.8ish is safe.
Old 09-02-2004, 04:30 AM
samz28's Avatar
this is the first time anyone has said that 4.8 is safe, is this on all model cars? i've seen my bro's 99 do 4.71 but i though the absolute limit was 4.7V.
i wonder if different years/models have different opening thresholds, otherwise im gonna go work it some more
Old 09-02-2004, 10:40 AM
Super Moderator
Reckless's Avatar
It was hitting 4.9V when we were having issues, and then we adjusted the TPS sensor itself so it could only get to 4.7-4.8, and the issue disappeared. I don't have the correct Helms manual, or I would look it up
Old 09-02-2004, 08:32 PM
LS1TECH Sponsor
Magnus's Avatar
Did you measure the blade position with a caliper?
Pull the TB and measure the distance on the motor side at WOT from both sides of the blade to the housing.
The cam can rotate on the shaft and vary your actual position vs sensor position.
Old 09-03-2004, 02:27 AM
383838's Avatar
There are just a lot of little variables that determine the max voltage. How hard the throttle is hit and voltage not being a completely stable reading are the main culprits.
Old 09-03-2004, 08:39 AM
SMOKINV8's Avatar
I just read about this on ls1tuning.
http://www.ls1tuning.com/iboard/index.php?showtopic=758
Old 09-03-2004, 08:55 AM
Moderator
jimmyblue's Avatar
Believe the TPS has to stay above 4.7V for some
period to fault; the higher the TPS voltage skew,
the easier to do this.
But definitely want to set up the mechanical
stop for dead-horizontal blade (center of throat
by ruler) and then adjust the TPS for electrical
output to match (dead center = 4.6V).
http://community.webshots.com/photo/...56178307xTnvId
Old 09-03-2004, 08:56 AM
Super Moderator
Reckless's Avatar
Site is down
Old 09-03-2004, 09:03 AM
SMOKINV8's Avatar
They're having some wierd problems with that site... It works fine for me right now.
Old 09-03-2004, 09:21 AM
critter's Avatar
I posted here a while back about that problem. I had to slot the TPS sensor holes and adjust the voltage down. The manual gave the threshold for throwing the code (it was in my post) but I don't remember. 4.7 rings a bell, but I can't be sure. In any case, the manual did not say what the effect of overvoltage was other than the code.
Old 09-03-2004, 09:49 AM
DrkPhx's Avatar
It's listed in Volume 3 of the manual. Here it is:
* The TP sensor is great than 4.8 volts
* All of the conditions are present for 3.5 minutes
Old 09-03-2004, 12:48 PM
Super Moderator
Reckless's Avatar
Thanks guys. and 4.8V would make sense in this case.
