232/236 cam ok with these heads?
Old 09-11-2004, 09:05 PM
guadofreak's Avatar
Default 232/236 cam ok with these heads?
I have a set of 5.7 heads that were milled .030. They have a 2.02/1.55(whatever stock size is stock size) SS valves and were ported etc...
My cam is an XE-R 232/236 .585/.585 113lsa set on 0 degrees of advance. My question is will this cam be to big for the motor since I am on a stock shortblock with NO flycutting?
I will not flycut the pistons so that is out of the question. I keep hearing conflicting advise on yes and no from many people. Any help would be great!
I will be useing the crane duals to avoid floating.
Thanx! ~Eddie
Old 09-11-2004, 09:28 PM
LS1Tech Sponsor
Slowhawk's Avatar
I would say no. The .030 milling is the catch.
Old 09-11-2004, 10:03 PM
guadofreak's Avatar
does the 2.02 valve really make that much diff in P/V issues assuming everything else is the same?
Old 09-11-2004, 10:08 PM
scalemaster's Avatar
well I'm runing STG2 205/160 valves but there not mill and my cam is 230 236/591 601 113 and no problems but then again there not mill
Old 09-11-2004, 10:10 PM
LSUxBlake's Avatar
I'm 98% sure its a no, but you wont really know till you have the motor mocked up.
Old 09-11-2004, 10:13 PM
guadofreak's Avatar
well this is sucktacular....
Old 09-11-2004, 11:41 PM
LSUxBlake's Avatar
I'll just put it this way. My roomate just bought a set of patriots LS6 style castings that were barely milled at all. They mocked up the motor with the F13 cam (230/232 .591/.581 112) and the clearance was too close for comfort.
Old 09-12-2004, 12:18 AM
ls1CANTU's Avatar
i installed a set of mti stage II heads milled .030 with 2.05/1.60 and 230/236 591/601 112lsa and did no have no problems at all car ran good.
Old 09-12-2004, 12:37 AM
guadofreak's Avatar
interesting.
Old 09-12-2004, 03:45 AM
PREDATOR-Z's Avatar
Guys you could go back and forth on this for years to come.
1- degree the cam
2- Clay to get a clearer picture (both intake and exhaust)
3- The best way is to use a dial indicator (in general clay readings are .02 off (+) than dial readings.)
IMO I wouldn't go with less than a .10 int & .12 exht clearance on any cam. These are street engines, not track only.
Some will tell you I'm running .08 etc... untill the day. If a spring brakes, (even a double) the valve will sag a little, but this is up to you.
Old 09-19-2004, 11:16 AM
BriancWS6's Avatar
A while back I was watching a performance shop install some 5.3's and a 232 236 cam and they had to mill the pistons. Said something about .040 of clearance, pretty dang close.
Old 09-19-2004, 12:21 PM
UnbelievabLS1's Avatar
Were you watching at TEA? If so, you were probably watching me install a set of heads on my car. It was a black 00' SS M6.
I flycut the pistons .060", and had approx. .125" of clearance. This was with a 2.055 int and 1.60 exh valve.
The cam was a Comp 232/236 .580/.580 on a 110 LSA, and 108 ICL. I had Comp grind it on thier Renegade lobes, which are the lobes the NMRA Renegade class racers use......needless to say it was pretty frickin nasty!
