Sotck manifolds on my H/C cam - how much is still on the table?
Currently I have a stock exhaust with the exception of a QTEC cutout (which gained 12 RWHP when the engine was stock). How much HP/TQ am I leaving on the table by not having long tubes?
D rock did pick up those numbers with jsut the header swap. i was there for the before and after dyno runs.
soon im goig not install long tubes to replace my mac mids. wonder how much ill gain
with that swap.
if weather is nice you comeing out ot jerssy mikes saterday D?
Eddie
with that swap.
Eddie
Yep , headers were the only mod. I was running constant 12.70s maybe a 12.6x every once in a while and the times droped to a 12.32 first run out and 2 12.2xS right after that. Also my mph went from constant 106s to high 110s. I am very pleased with my pacesetter headers.
Eddie, i'm gonna try to make it out there, Shaun(Formula99SD) is susposed to come over so we can work on his formie and i'll bring him out there if he wants to go.
Oh and they dyno numbers to be exact were 327.0 rwhp 306 rwtq before, 347.7 rwhp 348.5 rwtq after, keep in mind this is through an auto with a converter and a 12 bolt with a steel driveshaft. So more than likely you will pick up more hp and tq that I did.
Later,
Derek
Later,
Derek
D Rock. Seems your car is a little on the slow side and low power for the mods. Nice gains with the headers though. Are you still running the LS1 intake? What kind of 60s you pull'n? What kind of air do you get? Are you tuned for the cam? Stall speed?
Just curious.
Just curious.
Hey man,
I've heard a couple of people say that his dyno is a little on the low side. A friend just had his car tuned and it put out 375, and only put out a little more than 350 on this dyno a little less than a week later.
I still have the ls1 intake, stock pully, non ported throttle body, so i'm still living a little bit on the table. The stall is a 3500, and i'm cutting 1.6x-1.7x sixtys, i've only cut a few 1.6s. I am not tuned for the cam, so i know i'm still leaving a little bit there also, and i'm very happy with how my car runs for the time being, and thats what matters anyway.
Later,
Derek
Later,
Derek
Originally Posted by D Rock
Hey man,
Later,
Derek
Later,
Derek
To stay on topic, it seems 20-25 is average.
