9" is in, break in???
Old 09-22-2004, 04:11 PM
Tally TransAm's Avatar
Default 9" is in, break in???
cant wait to launch it on slicks
is there a break in period??
i am very happy with my decision to go 430's and auburn. car drives like stock and the gears are great even on the highway
Old 09-23-2004, 01:24 AM
991LE's Avatar
I think the break in is pretty simple.
For Street:
1. Just a 2 -3 minutes in forward and reverse up on jack stands.
2. Drive it around for about 10 miles and accelerate and decelerate at normal rates. and then let it cool for 1 hour.
For Drag racing, do step 1 above
Pull to the line
Old 09-23-2004, 01:29 AM
991LE's Avatar
The only problem I am having is that I don't think my pinion angle is right. I eyeballed it and it is pretty close. At least it is close enough that the U-joint isn't making noise like it was when I first installed it.
I am going to have to buy one of those pinion angle gauges to set it right.
Oh yea, congrats on the install!
Old 09-23-2004, 03:04 AM
2MuchRiceMakesMeSick's Avatar
How smooth was that install. I will be installing mine as soon as it gets here in the mail.
Old 09-23-2004, 06:37 AM
wasnt bad at all. i had to lower my exhaust a bit cause it was hitting the DS. stock style exhaust shouldnt have a problem though. also the sway bar was hitting the t/a mount so i had to rotate back a bit. other than that pretty straight foward.
get a friend to help cause that bitch is heavy. my back hurts so bad today
Old 09-23-2004, 07:49 AM
gomer's Avatar
If I had it to do over again, I'd definately would have went with 4.30's over my 4.10's. Can't wait to see what you run on slicks!
Old 09-23-2004, 10:46 AM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
Tally, enjoy the clutch dump launches.
Old 09-23-2004, 06:00 PM
I shouldnt have any problems exaust wize cause my true duals dump at the axle
Old 09-23-2004, 07:27 PM
i have a 3.5" i pipe and a 3.5" flowmaster that dumps before the axle. the muffler hangs just below and to the right of the DS. the new ds was a little lower so it hit. easy fix though
Old 09-23-2004, 09:20 PM
Turo's Avatar
did you NEED a new driveshaft for the 9", or did you get a new one just to upgrade at the same time?
Old 09-23-2004, 11:04 PM
991LE's Avatar
You don't NEED it. All you need is the correct Ujoint. Now if you plan on launching off the rev limiter with slicks, then you might NEED a new DS
Old 09-24-2004, 07:37 AM
Did it come with the U joint? If not where can I get one, how much do they cost?
Old 09-24-2004, 10:04 AM
991LE's Avatar
Mine didn't come with a U-joint, but I bought the center section seperate. I got the U-joint from the LSITech parts dept. (Parts for sale)
I would think that most of the sponsors on here would sell you the correct U-joint with the rearend package if you asked?
Old 09-24-2004, 07:25 PM
lemme correct, i didnt get a new ds, the new ds angle was a little lower
ttp has the ujoint, so does napa. part #447 i believe
Old 09-27-2004, 03:38 PM
gomer's Avatar
Go ahead and plan on buying a drive shaft... mine died on the first launch at the track on ET streets with the 12 bolt.. cost me $$$ for a damn rollback ride home.
Old 09-27-2004, 08:39 PM
LS1TECH Sponsor
badpewter-z's Avatar
good to see you got it in tally
you will learn to love it trust me, and the first run down the track you love it even more , and still drive home
cograts man
as for break in, jack stand runs, few street runs, for heat cycles
then let it fly
Old 09-27-2004, 09:39 PM
So who makes the strongest/best drive shaft?
Old 09-27-2004, 09:41 PM
LS1TECH Sponsor
from what ive seen and heard, dennys nitrous ready is preety bullit proof
