SLP Lid Rubbing
Try to re-adjust the bellows to make the lid move a little farther into the car. I have the SLP Lid and I don't seem to have the problem, although I have heard of it before.
-Todd
-Todd
Originally Posted by CMKworm
What should I do?
Seriously though, maybe just get a new lid.
If you have CAI, it makes it more difficult to adjust. As said above, you need to get it further back and all it takes is about 1/8 to 1/4 inch lower and you be good. Get some black touch up for the hood or put a sticker over it!
I have the SLP Lid, and the 2 clamps that hold it down never stay closed! Every time I pop the hood they have popped off....I adjusted the couplers and I still have the same damn problem.
it seems difficult to see how you other WS6 guys have an issue?...did yall tuck in the front lip of the lid behind the notch on the airbox or is it hanging over the end?my buddy's Z was hangin over...didnt want to clamp shut oso i set it up like mine....no issues (HES GOT THAT DAMN SLP MAF!!!! I HATE THAT THING! it makes everything difficult)
1) Untighten all clamps (lid->maf, maf->bellow and bellow->TB)
2) Unlatch the clips
3) Pull the lid just a little bit towards you, just so the tabs on the back get off
4) Put the lid back holding the front part slightly up, making sure the tabs go under
5) Press the lid towards the MAF
6) Press the lid down, making sure the lip between the metal clips is INSIDE the box
7) Latch the clips (they should latch good now, and stay there)
8) Re-tighten all clamps again
9) Done -- no more rubbing on hood, no more unlatching clips.
inside what box? do you mean the lid?...i have that lip hoding my lid on ther dont kno bout any of you other guys...i really dont think it makes amuch a differecne if at all....sealed better i thought...
Yes, about 85% of your lid goes inside that lip, the other 15% (the corners) go outside. That cleared up the issue for me
I had the same problem. I ended up fileing and sanding the bottom of the lid towards the rear if the lid. Took a long time, just removed a little bit at a time, but I finally got the lid to stop rubbing. It also closed up a small gap between the lid and lower box.
