View Poll Results: Have you been able to Quiet your Moser whine
Yes
3
42.86%
No
4
57.14%
Voters: 7. You may not vote on this poll
Poll:Have you been able to quiet your Moser?
Old 10-03-2004, 03:49 PM
firehawk933's Avatar
Default Poll:Have you been able to quiet your Moser?
Looking to see how many people have been able to quiet their Moser whine and if so, How? I'm looking into having a shop reset the gears to see if that works.
Old 10-03-2004, 05:33 PM
SNAXS's Avatar
No I havent Ive already resteted my gears twice by two different shops and still nothing...
Old 10-04-2004, 03:19 PM
1fastWS6's Avatar
1) Get MOTIVE gears,
2) Have them installed by a pro,
3) DO NOT LAUNCH HARD W/ SLICKS
It will stay quiet. Once you start going to the track it's going to get noisy again. Good luck!
Old 10-06-2004, 06:02 PM
Only 2 people have tried to quiet their Moser?
Old 10-07-2004, 09:39 AM
LS1TECH Sponsor
Steve Burger's Avatar
I had Billingsly install Motive gears in mine. They also had to machine the pinion race doe to a casting flaw in the housing. There was no way to set the pinion depth right other than to machine the race. The race cup on the housing was not deep enough so Jay had the race cut down to allow the bearing to sit back in the cup the way it should.
I have 70+ 5500 and north launches on mine since this was done. It is still quiet. Looks like I owe Jay a steak dinner.
Good luck.
Old 10-07-2004, 01:47 PM
blaSSt's Avatar
When I got the MOSER the gears HOWLED! Went to richmond gears and the best shop around. the whine can still be heard,but you have to listen for it. Once gears whine, they usually cannot be quieted down. But if you put in a new set and have it set properly it can get much better.
Old 10-08-2004, 07:08 PM
Just picked up my car from the shop. They checked the pinion depth, it was off, they shimmed it. It quieted the car down 75%. It still whines, but it is what I first expected it to be given the hardness of the gears.
Old 10-11-2004, 02:02 PM
z-ya's Avatar
7 ring and pinions 3 different installers 9 thousand miles=NOISE
Iam at the end of my patience with this 12 bolt ****.
