how much HP can a forged ls1 handle?
Old 10-03-2004, 09:41 PM
1quickformula's Avatar
Default how much HP can a forged ls1 handle?
just wondering how much a forged, stock displacement bottom end will handle without a girdle or an iron block.
Old 10-03-2004, 10:18 PM
goober35's Avatar
That is an open question. What parts? What RPM's. I bet i could get 300hp to distroy an forged short block if i spun it to 10000RPMs.
Old 10-03-2004, 10:21 PM
Ben R's Avatar
How much money are you going to spend?
Old 10-04-2004, 03:19 AM
SSactionLs1's Avatar
probably alot more than you will ever give it..
Old 10-04-2004, 03:43 AM
2MuchRiceMakesMeSick's Avatar
Depends on alot of things but in one word, ALOT
Old 10-04-2004, 12:13 PM
z98
z98's Avatar
900+ has been there, done that.
How much do you plan on doing?
Old 10-04-2004, 01:02 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Harlan is prolly making 1200 crank hp.
I made ~850-900 crank hp.
Old 10-04-2004, 01:06 PM
427's Avatar
We have made 1150hp at the crank here.
Kurt
Old 10-04-2004, 01:14 PM
STF Veteran
99-LS1-SS's Avatar
Those are some pretty stout numbers!
Old 10-04-2004, 01:24 PM
y2khawk's Avatar
Stock crank at that
Old 10-04-2004, 04:46 PM
Ben R's Avatar
Originally Posted by y2khawk
Stock crank at that
What kind of Main Caps do you use?
Old 10-04-2004, 06:39 PM
y2khawk's Avatar
stock powdered metal
Old 10-04-2004, 08:51 PM
z98
z98's Avatar
Hey harlan is your setup or can I see the specs somewhere?
Your website seems to be your old setup if I'm not mistaken.
Old 10-04-2004, 08:57 PM
cyphur's Avatar
harlan you're makin some sick power. you're also crazy!! stock crank....hahahaa
Old 10-04-2004, 09:15 PM
y2khawk's Avatar
Yeah, website is a little outdated.
Nothing secret about it, what you wanna know?
Old 10-05-2004, 10:06 AM
z98
z98's Avatar
Why stock crank?
How much power?
How high do you spin it?
What block, heads?
Cam specs?
How many cubes?
How do you hold the heads down?
Race weight?
(related to last question, may or may not be relevent depending on race weight) Why a powerglide?
Plan on being the quickest/fastest LS1?
Size turbos?
Where can I find more videos?
MPG ?
Who is the dork yelling "Oh my god!" in that video? I about shat myself the first time I heard it.
General Comments:
And please tell me you got video when you went "hunting for 'busa's".
Nice new time.
And, um, ...
That's all I can think about off the top of my head.
Old 10-05-2004, 10:57 AM
8 second mod
Noyzee's Avatar
Stock stuff will make good power. i made a tad over 700 with a 250 shot, stock cranck ect.
Matt, im curios as to how you keep the heads down as well? welded block? or big studs?
Old 10-05-2004, 11:44 AM
427's Avatar
I think he is using tuning.
Kurt
Old 10-05-2004, 11:47 AM
8 second mod
Noyzee's Avatar
Wow, i figured more then a good tune was needed, most people i have seen in the 800 range need to do other things. there tune was mint, no knock ect, nice af and all, but the cars still pushed a little water each pass
Old 10-05-2004, 12:06 PM
y2khawk's Avatar
Here goes....
Why stock crank?
Why not
How much power?
No real dyno numbers, had drag radials on when I first checked the base tune. Spun the tires anything past 18psi. Even w/ 6 straps on the back, and 4 people in the trunk.
shift at 7800, limiter at 8000
What block, heads?
LS6 block, 6.0L heads
Cam specs?
Futral solid roller 251/248 .695/.683 115LSA
How many cubes?
.010 over block, 348 cu in
good tune, GM MLS gaskets, standard ARP studs
Race weight?
was 3330 before the wheelie bars and chute, guessing ~3400 right now
Why a powerglide?
Recommendation of a friend with a fast mustang
If it is, so be it. Just out to have fun.
Size turbos?
T66 right now
they are coming soon
MPG ?
not sure, 140 miles and 10 gallons the one night. mixed driving
That would be Coach B, resident slacker
Quick Reply: how much HP can a forged ls1 handle?
