What else needed for cam swap?
Old 10-05-2004, 07:41 AM
LS69TA's Avatar
Default What else needed for cam swap?
I will be pulling the old motor/trans out of the car next week after I return home. The LS1 is still on a pallet b/c it arrived after I left for Iraq. I bought a G5X3 cam, Comp 921 spring kit and pushrods since I've been gone. What else if anything is needed besides the gasket kit I'll probably get from Thunder Racing? I know I'll need a new balancer bolt as well. Am I forgetting something or is this all? The lack of internet access has drained my memory
Old 10-05-2004, 10:38 AM
2000TransAmWS6's Avatar
if you get a chance, check out ls1howto.com, that guy includes a complete list of things you'll need with instructions on how to do the swap.
since your car only has about 18k miles you probably don't have to swap the oil pump and timing chain... its usually suggested to swap that stuff if your car has about 50k miles.
Old 10-05-2004, 10:46 AM
PREDATOR-Z's Avatar
Which G5X3 did you get? 112 or 114?
Old 10-06-2004, 04:44 AM
LS69TA's Avatar
I got the 112.
Old 10-06-2004, 10:38 AM
PREDATOR-Z's Avatar
You will need to flycut the pistons for sure. 2cc relief.
Old 10-06-2004, 11:03 AM
cyclerage's Avatar
Most likely.
Oil pump,waterpump, under drive pulley if you want, atleast a new balancer bolt, Roller rockers, if you want, Timing chain, LOCKTITE!!! for your rocker arm bolts, and alot of luck.
Old 10-06-2004, 11:25 AM
MYBLKSS's Avatar
Oil Pump O-ring!!!
Old 10-06-2004, 02:54 PM
luv2spd's Avatar
Originally Posted by MYBLKSS
Oil Pump O-ring!!!
Very true. Don't risk having to tear it all down just b/c you didn't put it a new o-ring!
Old 10-06-2004, 05:35 PM
xxboomer408xx's Avatar
U need a 150 shot of nitrous too. u gotta have that or else it just won"t work. lol . Jk!
