Size of coolant hose for a "custom" bypass?
Anyone happen to know a the size hose I need to run from the radiator neck to the front coolant pipe to bypass the throttle body? I know that the first part of the hose is bigger than the second half. I guess I would have to put a good hose clamp on gutentite on the smaller end.
Originally Posted by HavATampa
...One side is 3/8" ID the other side is 1/4" ID. 3/8"... I used a coupler from a Brewery parts house instead of the one size hose...
I did the 'coupler' method and used a 1/4" barbed brass piece, it's tight enough on the 1/4" side obviously but I had to really tightem down the clamps on the 3/8" side.
My question is, am I potentially starving the flow/hurting anything by using that little 1/4" coupler instead of the more commonly used 5/16" one at all?
I have a 3/8" one I could use but it might not fit the smaller 1/4" hose.
Originally Posted by Redlinez
Think there's a real hp gain from this?
That dyno sheet on BMRs site is interesting though, I wonder if someone really showed that kind of gain over multiple dyno runs.
